Old 03-09-2013, 08:01 PM   #1
90crxfreak
Member#: 318642
2012 WRX Premium
Default Stage 1 2012 WRX First time. Hows it look?
Since everyone else does it and gets piece of mind, I want some too!
https://docs.google.com/file/d/0B5ud...it?usp=sharing
90crxfreak is offline   Reply With Quote
Old 03-10-2013, 01:21 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
2016 STi
HyperBlue
Looks good.
You are a little shy of target boost below 5000 RPM but it holds well up top.
If you try the HWG map you should hit target boost below 5000RPM and the ECU should be able to adjust above 5000RPM to keep you at target boost.
Try it out and post the HWG log.
jebjkey is offline   Reply With Quote
Old 03-11-2013, 11:57 AM   #3
Cobb Tuning
Member#: 4803
Hi there. Log looks good. As jebkey mentioned, you are underboosting a bit. You can give the high wastegate (HWG) map a try to improve boost levels, if you like. The HWG map can be found in the maps section at cobbtuning.com. Use the Accessport Manager software to transfer the map from your computer to the Accessport and then reflash the map to your car.
Bill
Old 03-11-2013, 02:29 PM   #4
90crxfreak
Member#: 318642
2012 WRX Premium
After flashing to the HWG map this morning and I did a short log I noticed my car had a hard time starting when I just got back in it. It didn't want to turn over. So I just reflashed the normal one.
Also no lights were on....
Old 03-12-2013, 09:33 AM   #5
Cobb Tuning
Member#: 4803
When you reflash a map and then cycle the ignition for the first time after the reflash, the ECU will run some sort of diagnostic test on the drive-by-wire throttle system. During that period, it will prevent the car from starting. So, after you reflash a map, simply turn the ignition to ON and wait for 5-10 seconds and THEN start the vehicle. It will start right up then. That only has to be done the very first time after each map reflash. After that, you would start the car as normal.
Bill
