Old 03-09-2013, 08:14 PM   #1
05stidriver20
Member#: 241680
Default got a stage 3 log
can someone check out my stage 3 log. mods are on a 04wrx. vf39 sti tmic, sti pinks, full turbo back exhaust.
thanks
bryan
https://docs.google.com/file/d/0B1MB...it?usp=sharing
05stidriver20 is offline   Reply With Quote
Old 03-10-2013, 01:12 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Your screen name and the car do not seem to match, I was expecting a STi and was wondering what your stage 3 was.
I assume this is a 3rd gear pull; you did not mention anything about the gear you were in and speed is not in the log to let us know otherwise.
Your DAM is only 12, it should be 16. There is nothing specific I see in this log to explain why it is only 12. I would reset the ECU and see where DAM goes to after some driving. After the reset it will be 8, but if you check the sticky in Engine Management for Re-mapped ECU Learning Trick you can get it quickly up to 16.
How long has it been since you last reset your ECU or flashed a map to the ECU?
You have boost creep; your WDC goes to zero at 5818 RPM! I do not think I have ever seen this on a 2 liter VF39. It is possible that there is a problem with your WG system preventing it from opening all the way causing the boost creep. Check the WG arm and see if anything is binding it and if it moves freely through its entire range. You should not have boost creep on a 2 liter VF39, there must be some mechanical binding or something blocking WG movement.
What DP do you have?
jebjkey is online now   Reply With Quote
Old 03-10-2013, 08:26 PM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
They do creep, especially with intake/exhaust/cold temp.
This is from years ago. 04WRX, Air temp 32F, Cobb OTS map.
Airboy is offline   Reply With Quote
Old 03-11-2013, 12:23 PM   #4
Cobb Tuning
Member#: 4803
thanks
bryan
Hi Bryan,
For these stage 3 maps, the DAM should start out at 12 for the 91/93 octane maps and 8 for the 91ACN map, so the DAM at 12 is not a concern - just hasn't yet learned up to the max value of 16.
You have a pretty good boost spike and boost is uncontrollable at high RPM. You may be experiencing boost creep (especially if you have a catless exhaust) or you may have a problem with your boost control hardware:
http://www.cobbtuning.com/Technical-...es-s/70674.htm
Bill
