Old 03-10-2013, 07:07 AM   #1
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Default could I be over boosting?
So recently ive noticed I major drop in power so I started going down a list of things it could be and what it could be and then starting wirh the cheapest which was vacuum line, so I redid most of the vaccum line and now im reching 18.5psi in 5th and my lowest point of vcuum was 13.1?? Ive never seen #'s like this with this car could I be over boosting on a Stage 2 OTS cobb map? Or is this what I shouod have been pushing the whole time?? Idk im skeptical here.
2004 wrx
Mods
3in turbo back (dp has high flow cat)
Cobb ap stage 2 mapp
Cobb sf air and air box
The orher mods are irrelevant considering they have nothing to do with the engine,
All 2cents welcome.
Thanks
tjmmason93 is offline   Reply With Quote
Old 03-10-2013, 12:53 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
Datalogs would give you a definite answer...
Old 03-10-2013, 01:41 PM   #3
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Ill post several data logs as soon as I get home
Old 03-10-2013, 01:50 PM   #4
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
What should I record with the data log and ill do a 2nd, 3rd, and 4th gear pulls WOT from 2-6,5k
Old 03-10-2013, 11:11 PM   #5
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
how do i upload the data logs? im looking at them now but i dont see how to attach them to this message?
Old 03-13-2013, 05:38 AM   #6
Artizle
Member#: 251825
2004 WRX
Upload them on google docs and post link
Artizle is offline   Reply With Quote
Old 03-13-2013, 08:32 PM   #7
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
im going to upload them now
Old 03-13-2013, 08:46 PM   #8
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
https://docs.google.com/file/d/0B6B2...it?usp=sharing
this is 4thgear pull i believe
it also shows knock which bothers me
Old 03-13-2013, 08:52 PM   #9
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
3rd gear pull 1
3rd gear pull 2
3rd gear pull 3 this one shows over boost my 5thgear pulls are the worst but obviously to do a full pull will be easier said then done
3rd gear pull 4
Old 03-14-2013, 01:57 AM   #10
jebjkey
Member#: 73884
Chapter/Region: HIIC
2016 STi
HyperBlue
According to your logs you are underboosting.
I went to the Cobb website and looked up max boost for an 04 WRX using the OTS stage 2 map. Depending on what map you are using the max boost is:
ACN91: 16.0 peak, 12.0 @ redline
91: 16.5 peak, 12.0 @ redline
93: 17.0 peak, 12.0 @ redline
Your target boost is 17.79 peak and ~15 @ redline.
Are you sure you are running an OTS map?
Your actual boost is right in line with what the Cobb map notes say it should be for a stage 2 map. But your WDC is maxed out trying to hit 17.8 target boost.
You did have what initially looks like a small boost spike in 3rd gear pull 3. This is more than likely due to your target boost values and not really a boost spike. Hitting 18.1 with a target of 17.8 is just fine.
The question is why are your target boost values so high for an OTS map?
jebjkey is offline   Reply With Quote
Old 03-14-2013, 09:21 AM   #11
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
It may be an older version of the map. although with that big of a difference It sounds like it isnt OTS, possibly tweaked by previous owner?
endrswrd is offline   Reply With Quote
Old 03-14-2013, 09:53 AM   #12
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
As far as im aware its the most updated map, its it is the ots 93 octance map I never changed anything on it? Im going to try a 5th gear pull. .. thats where it reaches 18.5psi And I must ask whats up with the knock on the 4th gear pull
Old 03-14-2013, 10:05 AM   #13
jebjkey
Member#: 73884
2016 STi
HyperBlue
Download the current map from Cobb's website, load it in the car, and see if there is any difference.
What version is your map?
Cobb's current version is 3.1.
Old 03-14-2013, 10:06 AM   #14
jebjkey
Member#: 73884
2016 STi
HyperBlue
Originally Posted by tjmmason93 View Post
... And I must ask whats up with the knock on the 4th gear pull
It looks like noise from going WOT.
Old 03-14-2013, 10:16 AM   #15
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Ill check the version when I get back in the car I know for a fact it has been updated with in the past 2months and so the knock I dont need to worry about? I recently had a boost leak or was loosing boost somewhere so I replaced the msjority of the vacuum line would that have anything to do with it? I used 5/32nd washer fluid/vacuum cable if I remember correctly...
Old 03-14-2013, 10:42 AM   #16
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
That tubing should be fine, but using vacuum clamps / zip ties to seal the lines up is usually recommended.
Old 03-14-2013, 10:54 AM   #17
jebjkey
Member#: 73884
2016 STi
HyperBlue
If you see knock consistently at the same RPM / load combination then you should try and fix it.
The problem is, many times people see false knock when they quickly go WOT or quickly come off WOT.
If you keep track of the datalogs where you see knock going WOT and datalogs where you do not see knock going WOT, then it is easy to compare them and see if there is a RPM / load that consistently gives knock and a RPM / load that is consistently knock free.
If there is no consistency to the knock while going WOT, then it is most likely noise. If you are concerned, (assuming your AFR is not too lean or boost too high - which they do not seem to be) take away a couple of degrees of timing for the RPM / load combination where you see the knock while going WOT. If there is still randomly appearing knock events while going WOT, it is noise and not knock. ...who's there?
Old 03-14-2013, 11:07 AM   #18
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
The current map is stage 2 94 v310
Old 03-14-2013, 11:11 AM   #19
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Thank you for that information. I will begin to keep data logs organized so if I continue to see knock I know how to take care of it. Also I know this is sorta off topic but do you need a custom tune to run the setup I have and then add the sti top mount intercooler I was told no but im 2nd guessing that for alot of reasons
Old 03-14-2013, 11:38 AM   #20
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
You really should be okay on that map with the given mods. You may need to tweak the map a bit if you have consistent knocking like Jeb said above. Obviously a pro tune usually will net you a smoother tune / better MPGs / more power. But some people are completely fine with the OTS tune.
Old 03-14-2013, 11:43 AM   #21
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Not sure if any of u are local but im most likely going to through the top mount on and schedule an tune date with mach v
Old 03-14-2013, 12:08 PM   #22
jebjkey
Member#: 73884
2016 STi
HyperBlue
I assume you mean 93 not 94. Not sure why the target boost is so high, but OK.
I live in Naples, Italy. Although I am in Diego Garcia right now on a business trip.
Old 03-14-2013, 12:26 PM   #23
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Apologies yes I ment 93 and jesus thats not local at all lol. Should I try and reset the ecu. And reflash the tune. .. is their a possibility the ecu re learned and adjusted the target boost or is that not just not possible lol
Old 03-14-2013, 01:20 PM   #24
jebjkey
Member#: 73884
2016 STi
HyperBlue
Although the ECU does learn things over time, I doubt it changes the target boost [as in to everybodies knowledge it does not].
It will not hurt anything to reflash the map, though it may not do anything either.
Reflashing the map will also reset the ECU and therefore any learned values, such as AF Learning and FKL will be set to zero. No big deal, especially for what you are looking for. You should be able to get a datalog anytime after flashing the map to see what target boost is.
Old 03-14-2013, 02:52 PM   #25
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
That is what I will have to attempt and then see what the data logs compare as...
