#1 |
Member#: 348177
TXIC
Vehicle:2013 WRX STI Limited Stage II w/ Invidia TBE |
https://docs.google.com/spreadsheet/...2c&usp=sharing
https://docs.google.com/spreadsheet/...kE&usp=sharing Had this tune on my car for 3/4 of a tank. Was excited to get out and log a 4th gear WOT pull. First log I chickened out after I hit 95mph or so, the second I got it up there and then let it come down in gear as well. Took a video of the pulls too ![]() I noticed the one knock event, I am pretty sure it was a reflector in the road. What do you guys think?
#2 |
Member#: 323908
Vehicle:2013 BRZ ltd ISM |
That probably was a real knock event. Nothing major, but other then that your logs look healthy.
#3 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#4 |
Member#: 348177
TXIC
#5 |
Member#: 348177
TXIC
https://docs.google.com/spreadsheet/...UE&usp=sharing
https://docs.google.com/spreadsheet/...lE&usp=sharing Was only able to get 1 4th gear pull, almost to redline. I also logged a quick 1st-2nd take off from a stop sign. Looks like there are still some knock events, plus its learning values. I should switch to the 91 octane map shouldn't I? Probably the crappy HEB 93 octane gas. Last edited by ALOKIN; 03-11-2013 at 10:21 PM. |
#6 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#7 | |
Member#: 348177
TXIC
#8 |
NASIOC Manufacturer
Member#: 4803
#9 |
Member#: 348177
TXIC
https://docs.google.com/spreadsheet/...EE&usp=sharing https://docs.google.com/spreadsheet/...3c&usp=sharing Ok reflashed to Stage 1+SF 91 octane early this morning and drove around all day in traffic ~100miles. Got my new Beltronics Pro 300 in the mail today so I was a bit more apt to go do some logs. First log of the night was an almost to redline 4th gear pull. Second log is a full 3rd gear pull third is a full 4th gear pull to redline The results have me spooked. 1: there is something going on in the beginning of the pull (noise?) second there is some fine knock learning going on. The last pull of the night had no knock events, but still some fine knock learned values, but they are decreasing. What's going on? Ive got another 100 miles or so of driving to do tomorrow so I will need to refuel by the end of the day. Ill make sure to get some good 93octane. Hopefully a little more time for the ECU to learn the new map and some good gas will prove helpful. Last edited by ALOKIN; 03-12-2013 at 10:57 PM. |
#10 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#11 |
Member#: 323908
In some cases, OTS maps just dont agree perfectly with some cars. But most of the issues can be solved by alot of smoothing to the timing maps, and polishing the fueling tables. A good E tune / Protune will solve these issues 99% of the time. The other 1 % is reserved for murphy's law!
#12 |
Member#: 348177
TXIC
https://docs.google.com/spreadsheet/...EE&usp=sharing https://docs.google.com/spreadsheet/...VE&usp=sharing Drove around town today again ~100 miles. Went to shell and filled up with 93 (had a little less than a 1/4 tank of the old fuel remaining). It could be the placebo effect but I think the car runs smoother on the new gas. Went out tonight and did three more 4th gear pulls. I tried to start with a little higher RPMs (>3K ish). I also added the knock parameters you requested to the data set. It looks like there where no knock events and the fine knock learn is decreasing. Logs are posted in the order they were completed. |
#13 | |
NASIOC Manufacturer
Member#: 4803
Also, keep an eye on the A/F Learning 1 A,B,C,D values. You don't have to log these - you can just periodically check them via the live data function. For 08+ STi, each value should individually be within around +/- 8%. Bill |
#14 |
Member#: 348177
TXIC
Thanks Bill. Its currently on the 91 map so I'll keep it there for now. Now I understand the knock count values. Should I reset the ECU learned values? I'll probably take it easy for a few days and run this tank almost dry, then refuel with the Shell 93 and do some more logs. Ill report back.
#15 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#16 |
Member#: 348177
TXIC
https://docs.google.com/spreadsheet/...FE&usp=sharing
https://docs.google.com/spreadsheet/...2c&usp=sharing https://docs.google.com/spreadsheet/...Wc&usp=sharing I ran the tank almost dry with moderate driving this past weekend and refilled with Shell 93 tonight. I took it out immediately and did three 4th gear WOT pulls in S#. I added the fuel trim parameters you mentioned to the data log. It looks like there was one knock event on the first pull on cylinder 3, and nothing else for the other 2 subsequent runs. Fuel trims look good too. What do you think Bill, et al? |
#17 | |
NASIOC Manufacturer
Member#: 4803
Bill |
