Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 03-11-2013, 12:48 PM   #1
Flyerdena
Member#: 344617
2004 wrx sti
Default 35 qtz of oil in 6k miles
Hi everyone I was finally able to make my own thread. Ok so I purchased a 2004 sti with 139k miles on november car ran great but shortly after buying it, it was out of oil. So I filled her up, week to 2 weeks later she was almost dry again. The oil disappearance is a mystery. Starting in January the car started to act funny. Rpm's would fluctuate from 1500-stalling out. Not very enjoyable. Took it to several mechanics and they told me it was my rings, I told myself well before I buy a rebuild/upgrade kit let me actually do a compression test. Did the test and the results:145,151,150,155. We also checked to see if the coil packs were fine and replaced the Spark plugs with OEM subaru ones. While doing the passenger side I realized that one of the clamps on the bottom air box had broken thus leaving the box slightly opened.
I just need help on finding out the problem to the rough idleing and the eating of oil like a hungry hippo. On another thread I was giving some tips on trouble shooting but haven't gotten to it yet. One of which I will be trying today is unplugging the maf sensor and seeing if the car still starts.
Thanks for any and all input guys and gals.
Flyerdena is offline   Reply With Quote
Old 03-11-2013, 12:53 PM   #2
piratemosh666
Member#: 250902
2004 WRX STi
Platinum Silver Metallic
35 quarts in 6k miles??
Are you driving a fog machine? Seriously, mosquitos must hate you.
piratemosh666 is offline   Reply With Quote
Old 03-11-2013, 12:54 PM   #3
Flyerdena
Member#: 344617
2004 wrx sti
Lol no smoke out the back. Use to have little puffs but not anymore.
Old 03-11-2013, 01:03 PM   #4
mechatricity
Member#: 290592
04 WRX Wagon,
15 WRX 6MT CWP
BURNING that much oil, i would think you would have an extremely obvious mechanical problem- so i would guess you're leaking it.
Wandering idle would likely indicate an intake leak.
mechatricity is online now   Reply With Quote
Old 03-11-2013, 02:33 PM   #5
Flyerdena
Member#: 344617
2004 wrx sti
No puddles under the car. Put it up on the lift can't find anything so maybe a turbo seal.. But than what would cause my rough idleing?
Old 03-11-2013, 03:42 PM   #6
tuzzio
Member#: 292532
05 STI
That's absurd. Good luck, sir.
tuzzio is offline   Reply With Quote
Old 03-11-2013, 04:07 PM   #7
Leafy
Member#: 330625
2006 WRX
Wait so thats a quart every 170 miles. Yeah you're either hemorrhaging oil out of a massive leak, or it looks like you're fogging for mosquitoes while you drive. Or you have only dont 3.5 quarts in 6k miles which is just over a quart every 2k miles, which really isnt that bad at all.
Leafy is offline   Reply With Quote
Old 03-11-2013, 04:11 PM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
the motor is blowed the **** UP
Old 03-11-2013, 04:14 PM   #9
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
Your pistons probably have big black mountains on them from consuming that much oil. You will need to rebuild your motor. Nothing short of a new/rebuilt motor will fix this.
guroove is offline   Reply With Quote
Old 03-11-2013, 04:21 PM   #10
Andrewxxcarlson
Member#: 316415
2006 WRX
Holy ****, ridiculousness.
Start tearing it apart, take off downpipe and intercooler.
Andrewxxcarlson is offline   Reply With Quote
Old 03-11-2013, 04:37 PM   #11
KOSTI_510
Member#: 138860
2005 STI
32J
ouch....
KOSTI_510 is offline   Reply With Quote
Old 03-11-2013, 04:42 PM   #12
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
2 stroke STi!
35 qts in 6k is impressive man, really sorry to hear.
HeroCrank is offline   Reply With Quote
Old 03-11-2013, 05:11 PM   #13
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Ya man, you have big problems.
Try a leak down test if you can, but you have serious issues. I wouldn't drive it until you yank that sucker and get it fixed.
DHRDAN is offline   Reply With Quote
Old 03-11-2013, 06:28 PM   #14
CalvinT
Member#: 329025
2002 WRX Wagon
It could be a stuck PCV valve. They can cause rough idle. Also problems in your vacuum lines can cause a rough idle. How's the gas mileage?
You said you changed the spark plugs. What color were the insulator tips? They should be tan. Black is not good.
Anyway it seems your crankcase is being pressurized and forcing oil out when the engine is running. Crawl under and look for places wet with oil. Wipe them dry and drive the car a few miles. A drop every 20 feet is equal to a quart every 100 miles, so it wouldn't take a very big leak.
CalvinT is offline   Reply With Quote
Old 03-11-2013, 06:41 PM   #15
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
i would check the pcv valve. it almost sounds like the crank case pressure
is pushing the oil into turbo inlet hose and then back into motor.
there should evidence of oil being burned..look at tail pipe.
Old 03-11-2013, 07:20 PM   #16
Tripintaz
Member#: 245218
2013 STI Limited
My guess would be you have a Troll under your hood.
Tripintaz is offline   Reply With Quote
Old 03-11-2013, 07:54 PM   #17
Flyerdena
Member#: 344617
2004 wrx sti
There is traces of oil in the exhaust tip and can also smell it. Only time I would see smoke was under boost.
Old 03-11-2013, 07:59 PM   #18
Flyerdena
Member#: 344617
2004 wrx sti
A fellow member mention to unplug the maf sensor and see if the car still starts he said if it does it means I have a vaccum leak. Now was I suppose to take the maf sensor out or just unplug it because I just unplugged it.
Old 03-11-2013, 08:06 PM   #19
kcscoob
Member#: 31222
2005 Legacy GT wagon
6 speed, BNR 18G, E85
You are burning 35 quarts every 6 thousand miles and you are worried about the MAF sensor......really.
kcscoob is offline   Reply With Quote
Old 03-11-2013, 08:13 PM   #20
Flyerdena
Member#: 344617
2004 wrx sti
The maf sensor was for my idleing issue lol not the oil problem.
Old 03-11-2013, 08:37 PM   #21
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
^^^^this
Op if u were burning 35q for every 6k u would of suffered catastrophic failure a long time ago and plus there would be evidence of oil leakage or smoking mosquitos/.
Now 3.5q for every 6k would be more logical.
trev762 is offline   Reply With Quote
Old 03-11-2013, 08:40 PM   #22
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
Thirty five or three point five quarts?
Amazing Asian is offline   Reply With Quote
Old 03-11-2013, 08:49 PM   #23
Flyerdena
Member#: 344617
2004 wrx sti
Come on guys I put 35 for a reason Thirty Five qtz. I am the one buying the oil non stop at thes store lol. If it was 3.5 I would be fine.
Old 03-11-2013, 08:56 PM   #24
point78
Member#: 344329
2008 Wrx, 6mt
I would be worried if it was 3.5qts. 35qts is amazing.
point78 is offline   Reply With Quote
Old 03-11-2013, 09:04 PM   #25
Hoon Goon
Member#: 335538
2008 WRX - Hatch
You may want someone to follow you out for a drive. With that kind of consumption you are either leaving an EXXON Valdez trail, or you are smoking like Cheech n Chong's weed bodied van after the exhaust catches the rear quarter panel on fire. It simply is not vanishing into the 4th dimension man. There is only two possibilities here. Good luck.
Hoon Goon is offline   Reply With Quote
