Old 03-11-2013, 02:59 PM   #1
kingflar
Member#: 284698
2003 WRX
Default P1091 and overheating
I recently did a turbo swap on an 03 bugeye wrx installing the stock td04 turbo. I have intake, Perrin inlet, catless 3" downpipe and exhaust.
The car ran great til the seals in the original turbo went so I went with another stock td04. The car sat for about 3 months in a heated garage over winter while I got my finances and turbo in order. Now after the swap it over heats and check engine light comes on. I ran the code and came up with p1091. I know the code is the tgv stuck closed. But which one is it and where is it located on the intake manifold, and how to fix it?
As far as over heating I checked all the lines and there is no leaking that I can see or on the ground while idling. Would the code attribute to this?
Thanks for the help.
kingflar is offline   Reply With Quote
Old 03-11-2013, 03:12 PM   #2
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Did you refill the coolant and bleed the radiator after swapping turbos? As far as a tgv sticking you gotta pull the manifold off and find out which one it is. There's a few different economic ways of going about that situation depending on how mechanically capable and confident you are...
booSTin-scoobs is offline   Reply With Quote
Old 03-11-2013, 04:19 PM   #3
kingflar
Member#: 284698
2003 WRX
There is no other way to fix it than to take the manifold off? After some more research it is system 1. I have located each one but need to know which one it is. I have unplugged each one and cleaned the connection to no avail.
Oberheating = fixed.
Ps. Will it damage the motor if I drive it with this code? I am moving this weekend and don't want to pay to have it shipped.
Old 03-11-2013, 05:33 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
yes there is a way to check tgv's.
remove the motors and see if you can rotate the shaft.
driver side..
Old 03-11-2013, 05:47 PM   #5
kingflar
Member#: 284698
2003 WRX
Is this front or rear facing the motor on the drivers side?
