Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Vancouver Impreza Club
Old 07-11-2013, 04:03 AM   #1
yeedub
Member#: 210561
2011 STI
Default Wheel stud replacement
I ended up cross threading a lug onto a front wheel stud on my STI during a wheel swap. Anyone have an idea of the work/cost involved ? If its not too complicated I may DIY it and buy a stud from the parts department
yeedub is offline   Reply With Quote
Old 07-11-2013, 04:29 AM   #2
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
it's pretty easy... I've done it quite a bit now...
You need to:
-remove wheel
-remove caliper
-remove brake disk
-hammer out old stud
-put in new stud and use washer(s) and a nut to pull into place. Impact gun works wonders for this
-reassemble brakes
-put wheel back on (don't mess it up this time)
-drive...
Zefy is offline   Reply With Quote
Old 07-11-2013, 04:35 AM   #3
pistachoo
Member#: 175035
2006 WRX STI stg 2
CGM
I can vouch for Zefy's having done it quite a few times... lol
pistachoo is offline   Reply With Quote
Old 07-11-2013, 01:22 PM   #4
alexs001
Member#: 8096
1998 Impreza 2.5RSTi
Rally Blue Pearl
I fixed one with a thread die one time... much easier than replacing the stud if it isn't too terribly mangled
alexs001 is offline   Reply With Quote
Old 07-11-2013, 01:36 PM   #5
OTG
Member#: 313951
2006 STI
I just swapped all front studs on mine for longer ones. Zefy hit it right on but couple things I'll note:
Don't go over board pulling the stud in with an impact gun.
Use some lube on the threads too.
I prefer an air hammer to drive studs out but not every DIY guy would have one.
OTG is offline   Reply With Quote
Old 07-11-2013, 01:57 PM   #6
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
ya these are good points. With an impact gun, you can hear the sound change when the stud bottoms out. That's when you know you're done... Any more than that and the stud is very likely to break off...
Old 07-11-2013, 02:07 PM   #7
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
Cant you just double nut the stud and drive it in by hand either wrench or rachet?
coupe-a-loop is offline   Reply With Quote
Old 07-11-2013, 02:10 PM   #8
Kristo604
Member#: 301858
2009 STI
Obsidian Black Pearl
if you lube the stud, remember clean the lube off after.
(and what Coupe-a-loop said) double nut, or 1/2" washers, did mine recently (couple nights ago) by ratchet. air tools + studs = more broke studs. :P
Kristo604 is offline   Reply With Quote
Old 07-12-2013, 09:52 PM   #9
yeedub
Member#: 210561
2011 STI
How easily do the Brembos strip at the mounting holes when you take the bolt off? Been seeing many horror stories online. I'm used the the heavy iron sliding calipers on Hondas that are pretty strip resistant
Old 07-12-2013, 10:09 PM   #10
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
they strip often...
Old 07-15-2013, 11:02 PM   #11
jaydow11
Member#: 138952
2011 STI Hatch
Pearl White
I've had these sitting in my freezer for the past 3 years or so! I bought them for my 2006 STi but never got around to installing them. (they were in the freezer to help with the install).
You can buy them from me if you want, since I don't have an STi anymore
Part number is 40222-RS035
http://www.nengun.com/nismo/long-hub-bolts
Sell them for $60 shipped
Or, I'm heading to Whistler at the end of the month and we can do an exchange...
Let me know!
Cheers,
Jay
jaydow11 is offline   Reply With Quote
Old 07-16-2013, 02:31 AM   #12
yeedub
Member#: 210561
2011 STI
I ended up going to Richmond Subaru and it took 0.5hrs to get it replaced. The thought of stripping out the aluminum threads made be reluctant to DIY
Old 07-16-2013, 03:42 AM   #13
jpoon
Member#: 314339
07 Sti Ltd
How much did you pay? I'm not sure how much they charge per hour. Did you pay for a replacement stud?
jpoon is offline   Reply With Quote
Old 07-16-2013, 12:13 PM   #14
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
75 all-in?
FunkMasta is offline   Reply With Quote
Old 07-17-2013, 11:01 AM   #15
yeedub
Member#: 210561
2011 STI
it was 70 dollars for the labor taxed in and 8 dollars for the stud with tax
I got a replacement lug nut for free
