Old 09-21-2002, 01:18 AM   #1
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Default ANybody know how to get a oil drain pan bolt out when it is stuck?
My oil drain pan bolt seems to be stuck and I can not get it off. Anybody know any tricks?
Jasno999 is offline   Reply With Quote
Old 09-21-2002, 01:25 AM   #2
auwrx
Member#: 20803
WR Blue Pearl
If you happen to have a "gator grip" then that might help. When my roomate and I changed the oil in my rex for the first time it was all out hell trying to get that thing off. It took about 20 minutes of pulling and pushing as hard as I possibly could. Possibly try putting the wrench on the drain bolt and then hitting the end of the wrench with a rubber mallet for a while might work. Just keep trying and it will come off I promise. We almost thought we were going to have to take it to a shop that had air ratchets to loosen it up enough for us to get it off, but it finally came off. Good luck
auwrx is offline   Reply With Quote
Old 09-21-2002, 01:29 AM   #3
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Yeah mine was really tight too the first time I changed my oil..had one hell of a time....takes patience mainly...they must really torque that sucka on there.
WRX_02_227 is offline   Reply With Quote
Old 09-21-2002, 01:31 AM   #4
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
Default Re: ANybody know how to get a oil drain pan bolt out when it is stuck?
Yea.. swear at it alot and then try harder
I had to change my oil yesterday... broke down and bought an oil filter wrench cause the dang thing wouldn't come off. Had a hard time with the drain plug too but it finally gave. Maybe use some WD-40 or similar product and let it soak in for bit?
lenyx is offline   Reply With Quote
Old 09-21-2002, 03:23 AM   #5
cnk
Member#: 10757
2013 BRZ Limited 6MT
Just use a breaker bar to get it loose. It's only supposed to be 33lb/ft. but the factory bolts those things on like crazy. When you put it back in after draining the oil, tighten it until the crush washer compresses and it is snug.
Calvin
cnk is offline   Reply With Quote
Old 09-21-2002, 10:44 AM   #6
hedguy
Member#: 19500
02 WRX Wagon
You can increase the torque applied to the bolt by increasing the length of your ratchet. I used a pipe and just slipped it on. If you don't have one, one could use a large box end wrench.
Guy
hedguy is offline   Reply With Quote
Old 09-21-2002, 01:03 PM   #7
BOP
Member#: 8681
Post
this is pointless
BOP is offline   Reply With Quote
Old 09-21-2002, 07:41 PM   #8
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Not trying to be an ass, but make sure your turning it the right way.
garface is offline   Reply With Quote
Old 09-23-2002, 09:04 AM   #9
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Trust me I am turning the right way. Lefty loosey.
And I changed the oil 2 times before. I torqued it down and just crushed the washer but for some reason it is stuck like all heck. Same thing happened with my girlfriends Corolla. I might have to take it to a shop if I can not find an extra long wrench or a pipe to give me some extra torque. I just dont want to torque the entire dran pan off.
Old 09-23-2002, 09:10 AM   #10
CatchME
Member#: 22732
Get a breaker bar, like cnk said. They aren't very expensive. And it will help a ton anytime you have a bolt stuck. Its a very long bar with a hook up for a socket - in case you don't know what one is.
CatchME is offline   Reply With Quote
Old 09-23-2002, 09:26 AM   #11
cnk
Member#: 10757
If you can't find a breaker bar, just go to home depot and get a 18" or 24" long peice of 3/4" piping to slide over the socket wrench handle. That should give you more than enough leverage.
Calvin
Old 09-23-2002, 06:17 PM   #12
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Not I think I striped a section of the bolt and there is a chard of metal that will not let me get the bolt on any longer.
*** really.
Old 09-23-2002, 08:30 PM   #13
nqwan
Member#: 2916
02 duburu arr exu
go buy a screw extractor. its pretty much a counterbored screw that digs into the back of the bolt you're trying to get out. So as you ratchet counterclockwise, it will further dig into the stuck screw and turn that screw counterclockwise as well.
nqwan is offline   Reply With Quote
Old 09-23-2002, 09:22 PM   #14
bamfwrx
Member#: 23498
my02 GDB clone
95 escort rally car
vise grip
bamfwrx is offline   Reply With Quote
Old 09-28-2002, 01:08 AM   #15
cnk
Member#: 10757
I'd just stop what you're doing and take it to the dealer or Midas or something and have them take it out for you. Based on your experiences thus far, wouldn't want you to further damage anything else on the car.
Calvin
Anybody know how to get out of Photo Radar ticket? ebeck South West Impreza Club Forum -- SWIC 16 06-22-2004 01:52 PM
Anybody know how to get rid of IE Search Bar? kenshiro Off-Topic 11 04-20-2004 10:45 AM
Anybody know how to get rid of unwanted birds? chkltcow Off-Topic 30 12-11-2003 01:20 PM
Anybody know how to get a hold of ASR? Boeleni General Community 0 02-05-2002 03:55 PM
Anybody know how to get rid of daytime running lights? LttLDGN Interior & Exterior Modification 2 04-05-2001 05:53 PM
