Old 03-12-2013, 01:15 PM   #1
HALFnelson
Member#: 319959
2012 WRX
Dark Grey Metallic
Default 2012 wrx spacers with stock tires/wheels and bc br coilovers
Couple of questions.
1. Recommend me a good set of spacers that are good quality. Also will I need new lugs?
2. How do I measure what width size spacer I need? Where should I measure from? I don't want to roll the fenders at this point in time.
Thanks for the help!
HALFnelson is offline   Reply With Quote
Old 03-12-2013, 02:47 PM   #2
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
How wide do you plan on going? need a little more info more detail plz!
ClemRoo is offline   Reply With Quote
Old 03-12-2013, 04:21 PM   #3
sc00by4life
Member#: 97135
You need wayyyyyy more information.....
Old 03-12-2013, 04:44 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Aside from the horrible lack of info to help you, it's a HORRIBLE idea to run spacers on your car. You will want extended studs to safely run a spacer, which will require different lugs. Start researching.
Old 03-12-2013, 10:15 PM   #5
Member#: 301037
2004 Forester XT
What reason are you putting spacers on?
art@grimmspeed is offline   Reply With Quote
Old 03-13-2013, 11:25 AM   #6
HALFnelson
Member#: 319959
2012 WRX
Dark Grey Metallic
My tires are super sunken in to the body of the car now after the coilover install and I hate how they look. I just want the tire to be close to flush with the side of the car...probably 10mm-15mm speacers is all.
Old 03-13-2013, 11:48 AM   #7
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Now all you need to do is run a staggered setup and you'll be good to go
Mr Wrex is offline   Reply With Quote
Old 03-13-2013, 03:06 PM   #8
Kinjirra
Member#: 258345
2013 WRX
Plasma Blue
Sunken...as in the top of the tire is pushed inward? Kinda what it looks like from the picture. If so did you have it aligned afterwards? Other then the camber changing nothing else should have moved.
The fronts should be able to be lined back up. The backs I'm not sure of as my knowledge is limited to the 08's that didnt have camber adjustments and you needed to install adj LCA's.
Kinjirra is offline   Reply With Quote
Old 03-13-2013, 04:12 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Sunken as in not HERRAFRUSH like the cool kids.
Old 03-13-2013, 05:40 PM   #10
Dat8687
Member#: 243261
2004 WRX
Java black pearl
FICs(SSR) 15mm spacer Actually designed for Subaru fits the hub-bore etc.. But they are like 200 bucks.. HR spacer they make a 20mm DRM style for it etc..
If I do spacers for my 17x7.5s its gonna be 20mm rear HR and 15mm fics(SSR) front
Dat8687 is offline   Reply With Quote
Old 03-13-2013, 07:03 PM   #11
sc00by4life
Member#: 97135
Lol. Don't want fender mods? You don't need spacers. At extremely low ride height, even more conservative fitments can run into fender clearance issues.
Old 03-14-2013, 03:58 AM   #12
GrumpyPitbull
Member#: 313311
I'm no suspension/tire expert, but looking at your picture I see no way you are going to avoid rolling the fenders. I'm kinda suprised they aren't rubbing already. If you push them out at all, they will rub, and that means rolling.
So basically you need to either accept you will be rolling fenders, or accept how they look now.
GrumpyPitbull is offline   Reply With Quote
Old 03-14-2013, 11:24 AM   #13
Bov_Rider
Member#: 142667
2006 WRX TR
Metallic Gray
well, you might want to save some money and get wider wheels and roll your fenders although many people are running on spacers with no issues.
Bov_Rider is offline   Reply With Quote
