Old 03-12-2013, 04:06 PM   #1
steve2788
Member#: 346875
2013 wrx sedan
SWP. TP stage 3
Default Bad idle boost 2013 wrx
Hi, i my 2013 wrx which is currently stage 1+ cobb sf intake
my idle boost is sitting around -11 to -10psi boost and i thought that was perfectly fine but i was told today that i might have a minor leak causing this.
i just wanted to get a little feedback on if those numbers are abnormal and what/where the problem might be.
steve2788 is offline   Reply With Quote
Old 03-12-2013, 05:07 PM   #2
2011boostdwrx
Member#: 263470
What is idle boost? Check your AP, what does it say or is this off the AP?
2011boostdwrx is offline   Reply With Quote
Old 03-12-2013, 06:59 PM   #3
rquinn19
Member#: 341182
2011 WRX
SSM
Vacuum.
Vacuum leak somewhere
rquinn19 is offline   Reply With Quote
Old 03-12-2013, 09:30 PM   #4
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
cobb intake issues i bet. do a search. there is a reason soo many are for sale here.
424wrx is offline   Reply With Quote
Old 03-12-2013, 09:41 PM   #5
steve2788
Member#: 346875
2013 wrx sedan
SWP. TP stage 3
My AP says idle is at -10 psi, ill do my research on the Cobb intake, I'm taking it to a car shop and if they can't find the leak I might try a new intake
Old 03-12-2013, 09:50 PM   #6
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Are you serious? Is this like the guy that was saying Rotella T6 was causing engine failures?
mechatricity is offline   Reply With Quote
Old 03-12-2013, 09:57 PM   #7
ryansx
Member#: 324527
2013 wrx
white
I'm still confused. You're complaining that you have negative boost sitting at idle? So you're car is fine because you don't boost at idle?
ryansx is offline   Reply With Quote
Old 03-12-2013, 10:21 PM   #8
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
this..
BigRob74 is offline   Reply With Quote
Old 03-12-2013, 10:23 PM   #9
steve2788
Member#: 346875
2013 wrx sedan
SWP. TP stage 3
No I'm concerned because idle vacuum is suppose to be around -20psi and I'm at -10psi that is kind of a big difference that I should worry about...
Old 03-12-2013, 10:29 PM   #10
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
There is NO Boost at idle, during idle you have vacuum. Please do not confuse people with bad terminology.
No. The OTS tune for Cobb+SF Intake is just fine. Plus a protune will eliminate any "issue" you might think of. MAF Scaling is the issue that intakes cause, no one intake is that much harder to fix for it.
"New" intake won't change a thing. Plus a different intake will require a protune.
Says who? Nothing in any of your posts say any problem EXCEPT an overly worried owner. If you are that worried, do a DATA LOG and send it to Cobb or post it in the Engine Management section.
Old 03-12-2013, 10:29 PM   #11
ryansx
Member#: 324527
2013 wrx
white
You don't read vacuum in psi, you read it in hg/inch^2. And although I don't personally have an ap, I have read on here from other threads with almost same concern, that it reads only in psi. So if you converted it I bet you would come up with being perfectly normal.
Old 03-12-2013, 10:32 PM   #12
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Where r u getting your info about -20 cuz mine has always sat around -7 to -9.7 with or without a cai.
trev762 is offline   Reply With Quote
Old 03-12-2013, 11:10 PM   #13
superdonkey23
Member#: 350000
2013 WRX
Crystal Black Silica
There is no possible way to have -20 psi of vacuum on this planet. Maybe if you drove to Saturn you could see the levels you want. Vacuum on the AP is read in psi, but vacuum is usually measured in Torrs for Torricelli an early Italian physicist (1608 - 1647). A Torr is equal to the displacement of a millimeter of mercury (mmHg) in a manometer with 1 torr equaling 133.3223684 Pascals above absolute zero pressure. Vacuum is often also measured using inches of mercury on the barometric scale or as a percentage of atmospheric pressure in bars or atmospheres. Low vacuum is often measured in inches of mercury (inHg), millimeters of mercury (mmHg) or kiloPascals (kPa) below atmospheric pressure. "Below atmospheric" means that the absolute pressure is equal to the current atmospheric pressure in inches of mercury (e.i. 29.92 inHg) minus the vacuum pressure in inches of mercury. Thus a vacuum of 26 inHg is equivalent to an absolute pressure of 4 inHg (29.92 inHg - 26 inHg).
So in layman's terms. Your idle vacuum is just fine. You're just confused because the AP reads it in psi instead of inHg like a normal boost gauge.
superdonkey23 is offline   Reply With Quote
Old 03-12-2013, 11:25 PM   #14
steve2788
Member#: 346875
2013 wrx sedan
SWP. TP stage 3
Yea i derped pretty hard there. I even took out my intake checking that everything was air tight. Well sorry for this stupid thread but at least I know that my car is ok now. Thanks a lot for the input everyone!
Old 03-12-2013, 11:41 PM   #15
Harbs
Member#: 335235
05 Liberty GT
My boost gauge reads -20 at idle.. I drive a 9.5:1, 2.0L though.
Harbs is offline   Reply With Quote
Old 03-13-2013, 12:15 AM   #16
heyitsjeff
Member#: 297441
2007 GT30R WRB STI
Let me preface this by saying I had a 2003 Wrx that idled at -20 something psi and have had a 2011 Wrx and my current 2013 sti idle at -11 or so. Read on to find out why.
In my 2003 Wrx I had a prosport digital boost gauge. When looking at the gauge at idle it would read -23 to -24 psi but my access port reading in the car AT THE SAME TIME was at -10 to -11 psi. In both my GV subarus I used/use an access port to read boost levels and the levels read around the -10 to -11 psi.
The reason is the boost gauge runs off of an actual vacuum line off the turbo. The access port is based off of the actual sensor from the cars ECU. While in boost each read the same. From reading the post about 3 before mine the different scales of measure makes a ton of sense too. I'm going to believe his because it sounds smart haha.
I'm guessing your reading your boost around -10 psi off an access port? If so your fine.
heyitsjeff is offline   Reply With Quote
Old 03-13-2013, 12:54 AM   #17
garudatwo
Member#: 322385
Mine sits at 24 at idle
garudatwo is offline   Reply With Quote
Old 03-13-2013, 12:58 AM   #18
Andrewxxcarlson
Member#: 316415
2006 WRX
Mine sits about -22psi at idle with turbosmart boot gauge tee'd to the recirc line on stock bpv.
Andrewxxcarlson is offline   Reply With Quote
Old 03-13-2013, 01:14 AM   #19
superdonkey23
Member#: 350000
2013 WRX
See how it says psi when it goes above 0 and then inHg when you are below 0? You are reading your gauge wrong if you think you are 20 psi in vacuum.
Old 03-13-2013, 10:18 AM   #20
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
This thread is such an enormous facepalm. Vacuum is not measured in PSI.
Old 03-13-2013, 10:41 AM   #21
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
1psi = ~2.04inHg. Do the math...
Mr Wrex is offline   Reply With Quote
Old 03-13-2013, 12:14 PM   #22
QueensEng
Member#: 208469
2011 WRX
^ This.
QueensEng is offline   Reply With Quote
Old 03-13-2013, 12:29 PM   #23
themaus
Member#: 321211
This thread contains so much fail.
Your accessport reads vacuum in PSI.
themaus is offline   Reply With Quote
Old 03-14-2013, 03:04 PM   #24
Tripintaz
Member#: 245218
2013 STI Limited
Cobb read PSI in vacuum. Most Boost gauges show Hg in vacuum.
10psi = approximately 20Hg. There is nothing wrong with your car, just its owners ignorance.
Tripintaz is offline   Reply With Quote
Old 12-05-2013, 03:38 PM   #25
CriticalityEvent
Member#: 281670
2012 WRX
Well, not usually. While it’s standard in most industries to measure vacuum in inHg or mmHg, this is pretty much for user-friendliness. Take a look at the gauge:
I used to do analysis and design for a company that manufactured medical suction devices. Our high-vacuum regulators would start at 0 mmHg while off, and go down to -760 mmHg at full vacuum (not a level you should typically apply to a human, FYI). The gradations between 0 and -760 mmHg are much easier to see than 0 and -14.7 PSI.
I think superdonkey hit it on the head with his post:
The way I look at pressure is that you can go MUCH higher, but only so low. Remember what pressure is: it’s particles that exert force over a surface. The elements and molecules that make up the atmosphere have instantaneous velocities of hundreds of feet per second (depending on temperature).
At sea level, we’re at about 14.7 PSI of pressure. If you have a boost gauge that is reading 0 PSI when the car is off, that means it is reading GAUGE pressure, not ABSOLUTE pressure. For our purposes, going below 0 PSI gauge pressure (14.7 PSI absolute) means reducing the number of particles in a volume. That being said, there should be NO measurement on ANY gauge below -14.7 PSI. This would mean that you have less than nothing in that volume because -14.7 PSI on the gauge is 0 PSI absolute.
If you start your car and idle, it should go down to about -10 PSI (4.7 absolute) if your engine is drawing air in and the turbo isn’t forcing anything, which leads to Hinshaw’s comment:
When your engine is under load, your turbo will build boost pressures, bringing your gauge pressure above 0 PSI.
This is where my confusion begins. I have a logging tool that measured my idle boost pressure at around -24 PSI. After changing a setting, it measured it at -9 to -10 PSI, not unlike heyitsjeff’s experience:
Assuming anyone has read this far, I would like people to note that both heyitsjeff’s numbers and my numbers made shifts of about 14 to 15 PSI. Remember what the difference is between gauge and absolute pressure? 14.7 PSI. The setting I changed in my logger reset the base point for my pressure, so I may have to disagree with heyitsjeff about it being a scale issue (assuming he’s talking about inHg vs. PSI).
What the hell are these gauges supposed to be measuring and where are they measuring from to get readings of -23 PSI?
CriticalityEvent is offline   Reply With Quote
