Old 03-13-2013, 03:21 AM   #1
Jinner
Member#: 343757
2005 STi
Default bad gas causing knocks?
So back in December I'm up in Nevada visiting a friend, i filled up 2 days prior and it had been about 4-5 miles, i let her borrow my car to run to the gas station to buy some stuff. She comes back with this horrible look on her face and tells me that my car is making horrible sounds. This is my first forced induction car so I'm shaky at best. In the end, the final question, could bad gas sound like the worst knock ever in these cars? Even at idle? Or am i looking at mechanical failures? When i was running it to try and figure out what was going in, it threw a giant cloud of black/dark gray smoke and stalled.
Jinner is offline   Reply With Quote
Old 03-13-2013, 03:46 AM   #2
Jonney2k
Member#: 349510
2012 WRX
Did you make sure it was gas when she got back ?
Jonney2k is offline   Reply With Quote
Old 03-13-2013, 03:50 AM   #3
GrumpyPitbull
Member#: 313311
Yes, bad gas can cause knock and other weird stuff. But I find it suspicious that this started magically happening after you let someone else drive your car.
Depending how much gas is in the tank, you could try putting some other gas in ... or drain it and refill. If it's still doing it with new gas, then you know you have bigger issues.
GrumpyPitbull is offline   Reply With Quote
Old 03-13-2013, 08:31 AM   #4
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Video of what it sounds like?
Mr Wrex is offline   Reply With Quote
