Old 04-13-2010, 08:22 PM   #1
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Default Quick Question: Transfer Duty Solenoid.
I'm looking at the 05 Impreza FSM, and there's a pin labeled transfer duty solenoid.
Is this the solenoid that controls Front-Rear power split on the center diff?
formula91 is offline   Reply With Quote
Old 04-14-2010, 03:07 AM   #2
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Sounds like that's what it is talking about to me. Here's the solenoid.
http://opposedforces.com/parts/impre...llustration_2/
Item #1 in the illustration.
They call it a "Valve assembly-transfer clutch" in the parts catalog. It would be nice if the FSM and the parts catalog used the same names for everything, but the names are usually totally different.
FourOnTheFloor65 is offline   Reply With Quote
Old 04-14-2010, 12:43 PM   #3
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Yes, it's so confusing. People call it Solenoid duty c, and then some years they called it Transfer Duty (C) Solenoid, and then in my FSM just transfer duty solenoid.
I'm not even sure if it's the right one, there's like 3 more solenoids on the AT.
High Clutch, Low Clutch, and lock up duty.
Perchance would you know what any of these solenoids do?
Old 04-18-2010, 03:33 PM   #4
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
transfer duty solenoid, solenoid c are the same solenoid located in the rear of a 4eat transmission. its what is used to control lockup of rear clutch pack that controls awd.
if you put the fuse in the fwd location it locks this solenoid in the bleed position so you dont have awd, front wheel drive only
bswilmington is offline   Reply With Quote
Old 02-14-2012, 08:26 AM   #5
daigljus
Member#: 286029
There seems to be two part numbers thrown around out there on the forums I've been researching: 31942AA090 and 31942AA103. I am wanting to replace the one in my 98 Forester... how do I find out which is the right one?
daigljus is offline   Reply With Quote
Old 04-26-2013, 02:30 PM   #6
CNY_Dave
Member#: 354655
Both are on this page- edge of a year change can be tricky.
http://www.subarupartsforyou.com/cp_...sion+Solenoids
CNY_Dave is offline   Reply With Quote
05 outback transfer clutch solenoid help Subieformance_Guy Transmission (AT/MT) & Driveline 0 09-19-2008 07:26 PM
wastegate duty solenoid chadlee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-26-2005 12:01 PM
duty solenoid c patcal Transmission (AT/MT) & Driveline 0 11-07-2003 06:37 PM
Duty Solenoid C location? Joelk Transmission (AT/MT) & Driveline 11 01-16-2002 07:05 PM
Duty Solenoid C......Expreiment? phastSVX SVX Forum Archive 4 02-13-2001 01:12 PM
