Old 03-13-2013, 09:36 AM   #1
Swpsti2013
Member#: 328778
2015 STI
Galaxy Blue Silica
Default Brake Squeak
Hey Everyone
I have a 2013 sti and this problem happens generally when coming to a stop but with the wheel turned either left or right. Would just like to know if anyone else experiences something silmilar
Swpsti2013 is offline   Reply With Quote
Old 03-13-2013, 09:53 AM   #2
Abgrooms
Member#: 298640
'14 WW Evo X GSR
Nitrous Rhodes
My STI had alot of brake squeak for the first 1500 miles, and got worse as the brakes got hotter in city traffic. Now at 3700 miles it seems to have gone away, although its been pretty damp and cold the past several weeks and I haven't been doing much city stop and go.
The 04's brakes got squeaky from heat also, heavy traffic or right after an autox run.
I hear a "grone", (light grinding noise) from the rears all the time, but my 04 did the same thing.
Brembos are just loud and noisy in general, nature of the beast.
Abgrooms is offline   Reply With Quote
Old 03-13-2013, 10:03 AM   #3
StateKDizzy
Member#: 335422
2013 STi Sedan
Moisture????
StateKDizzy is offline   Reply With Quote
Old 03-13-2013, 10:13 AM   #4
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
Stock pads are notoriously 'loud'. Only solution I've heard if you want to go with an OEM pad is to start using the 2007 pads, which are the same dimensions. Past that you can clean your rotors more with water to remove excess brake dust, or try going for a different aftermarket solution once you are needing to change them.
Napalm3nema is offline   Reply With Quote
Old 03-13-2013, 02:38 PM   #5
crick0234
Member#: 319696
2012 Subaru WRX STI
yup, brembos squeel some time. i've not had that before and thought possibly something wrong with it. NOPE, everyone else seems to have it. mine has gotten a lot better... its at 20K miles now. every now and then when coming to a slow stop it might squee a bit.
crick0234 is offline   Reply With Quote
Old 03-13-2013, 03:53 PM   #6
sc00by4life
Member#: 97135
Originally Posted by Swpsti2013 View Post
Hey Everyone
Brakes make noise. Imagine that.
Old 03-13-2013, 04:18 PM   #7
Lindyn11
Member#: 326221
2011 WRX
WRBP
My '11 WRX brakes don't squeak a lick. We should swap!
Lindyn11 is offline   Reply With Quote
Old 03-14-2013, 10:40 AM   #8
Atomic Rooster
Member#: 204224
2010 STI
Obsidian Black Pearl
From my experience, if brakes don't squeek, they probably aren't very good. Pads that have good bite to them tend to squeek.
The stock pads squeek a little. Greasing the caliper & that little plate between the pad & caliper does help somewhat. If you're getting outrageously loud squeeling, I'd try that.
My Hawk HP+ pads squeek more than stock, and it seems especially so when they're cold. In reverse they howl very loudly, and I believe it's those little plates - people who have them on backwards have serious noise issues.
Atomic Rooster is offline   Reply With Quote
Old 03-14-2013, 12:38 PM   #9
Mike.J
Member#: 174522
08 STI
FNGs. Get some anti squeal brake lube at your local parts shop and use it according to the directions. It takes maybe 5 min. a wheel. RTFM! You do NOT rub the lube on your rotors. Though that would stop the squeek.
Mike.J is offline   Reply With Quote
