Notices
Old 03-13-2013, 07:13 PM   #1
IamWill
Member#: 350085
Default New WRX owner, new problems
Whats up everyone, new to the forums and the WRX platform. Little bit of background on how this came about, so i have a '92 240sx with an SR20 swap that was my money pit and means of transport. It was a blast but decided i wanted something newer and more "grown up" so i sold my 240 2 weeks ago and picked up this running project (2002 subaru WRX) with some noticeable mods done to it:
Brand New XXR wheels with tires
Cobb accessport
Ported and polished heads
Brian crower titanium valves 1mm oversized
Brian crower copper valve guides
Super tech dual valves springs
Catless up pipe
Big 16g turbo
Big TMIC
Dw 750cc injectors
Dw 255lph fuel pump
4 ply silicon turbo inlet pipe
Cobb short ram intake
Invidia Catless dp
Strait piped Catless exhaust
No name lowering springs
New oem shocks n struts
Clock pod gauge pod with boost/afr/oil pressure.
Now the list of fixes:
-doesn't have power steering or AC
-Handbrake doesnt seem to properly work and feels very loose
-doesn't pass emissions due to it being straight piped
-having a power issue where it feels sluggish untill i hit 3k RPMs (one cylinder has lower compression than the other 3 which are right on point)
I think it may be a bad valve and i've been told by a mechanic it could be that or if im unlucky it may be a piston ring starting to go bad
-Cam seals and rocker stopper gasket need to be replaced due to oil leak but ive been told this is common for a WRX
-Car smokes at WOT i'd expect that partially due to the straight pipe, but i also feel the car could use a tune due to the big injectors and upgraded turbo. I was told its already been tuned before but i dont think so, maybe it was when it had like half the mods it has now so im gonna get a safe street tune soon to play it safe since im on a stock bottom end as far as im aware.
For starters i wanna tackle the low compression on cylinder 2 its my biggest concern. I'll do a compression test again soon and put the numbers up. If anyone knows what it could be or what to look for please let me know or ask for anymore info and ill try to add whatever information is needed thank you!
IamWill is offline   Reply With Quote
Old 03-13-2013, 07:21 PM   #2
slayer44wagon
Member#: 300834
03 wrx wagon
I hope you did not pay vary much for this thing.
slayer44wagon is offline   Reply With Quote
Old 03-13-2013, 07:24 PM   #3
IamWill
Member#: 350085
Nope not at all. To put it in perspective, i bought the WRX with the money i got from selling my 240 and still have money left over to fix most of the problems.
Old 03-13-2013, 07:57 PM   #4
danger1138
Member#: 279525
04 rex luger!
How many miles on the wrx? low compression on cylinder 2 is potentially a big deal. Post the numbers, but u may be in for a rebuild.
danger1138 is offline   Reply With Quote
Old 03-13-2013, 08:06 PM   #5
kelsyf13
Member#: 339401
Pop your oil cap off when its idling check for smoke, if it is could be ringlands.
kelsyf13 is offline   Reply With Quote
Old 03-13-2013, 08:11 PM   #6
IamWill
Member#: 350085
right now the cars just at 116,000 miles, but i have no idea if the car ever had a motor swap or not.
I will deffinetly check for smoke if its the ringlands. Even when its just turned on, idling or driving, smoke comes from under the hood but you can see its from the oil that leaks from the bad cam seal and burns when it hits the block
Old 03-13-2013, 08:21 PM   #7
IamWill
Member#: 350085
I think the previous owner coulda have been running high boost as well and this may possibly be the cause of possible piston ring going bad. I won't know anything for sure until i get the head off and disassembled
Old 03-13-2013, 09:19 PM   #8
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Good luck sounds like you got alot o bugs to work out
Dat8687 is offline   Reply With Quote
Old 03-13-2013, 09:52 PM   #9
IamWill
Member#: 350085
yep yep thanks i'm gonna need it !
Old 03-13-2013, 10:13 PM   #10
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
knowing your compression numbers arent good i'd be saving money for a new block.
easiest route would be to just replace with another 2.0L block but if you want to mod your car you could save a few more cash and upgrade to a 2.5L (sti) block and run a hybrid setup. theres tons of hybrid threads if you want to start researching lol
you can adjust the e brake once you remove the rear rotors. you can adjust the drum brakes depending on how worn the pads are.
Cois32 is offline   Reply With Quote
Old 03-14-2013, 12:46 PM   #11
IamWill
Member#: 350085
Yea thanks for that advice, I mean I don't plan on modding it any more than it is, I just wanna get it up and running and get a safe street tune on it. Anyone know how much a block for these cars goes for?
Old 03-14-2013, 12:51 PM   #12
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Originally Posted by IamWill View Post
Yea thanks for that advice, I mean.I don't plan on modding it any more than.it is, I just wanna get it up and rning and put a safe tune on it. Anyone know how.much a block for.these cars goes for?
I have heard people say cheaper, but I called a local dealer and for a brand 2.0L short block they wanted like $2300.00ish. Again, I thought they were cheaper, guess not.
And if that does NOT sound expensive to anyone.....I will give you my address and can you please have 1 shipped to me
Thanks
shamrock 05 is offline   Reply With Quote
Old 03-14-2013, 03:08 PM   #13
SR33
Member#: 330169
2005 WRX
Flatirons tuning sells new 2.0 short blocks for just under 1800. They also sell new EJ257 short blocks for exactly 1800. A little cheaper.
SR33 is offline   Reply With Quote
Old 03-14-2013, 04:06 PM   #14
IamWill
Member#: 350085
Yeaaaaah no i don't have that spend to on a block, if i'd get one i'd probaly get a used one. After all i just wanna get the car up and running for daily use, not aiming for crazy numbers on the dyno, hopefully i can find somewhere local whose got EJ20 blocks/heads
Old 03-14-2013, 04:59 PM   #15
slayer44wagon
Member#: 300834
03 wrx wagon
You thought your 240 was a money pit...
Old 03-14-2013, 05:19 PM   #16
IamWill
Member#: 350085
LOL damn guys so far the WRX crowd seems a bit pessimistic, lighten up nothing wrong with a little bit of hope. As for being a money pit, i hope it doesnt turn into that, but at the low price i bought the car i could,hypothetically speaking, swap out the whole motor and still not have spent what the list price of this car even is so im not worried at all about losing money or anything like that. I posted something in the detailing section about exhausts leaving residue on bumpers and i get harshly negative replies like DERP CAR SMOKING, NEW MOTOR (exaggeration, of course) BUT! i'm hopeful it will all work out, i brought my 240 from the absolute pits of hell to a work of art and im hoping to do the same with the WRX.
Old 03-14-2013, 05:33 PM   #17
ToneWrx02
Member#: 239095
2002 Wrx
you domt know how expensive these car get....
ToneWrx02 is offline   Reply With Quote
Old 03-14-2013, 06:05 PM   #18
Nikryj
Member#: 346659
2003 WRX
Yes. Very expensive. I'm learning the hard way.
Nikryj is offline   Reply With Quote
Old 03-15-2013, 10:00 AM   #19
shamrock 05
Member#: 120057
So it looks like they only have the 257 short block and no 205's
But.....how is a 2.5 SB $1800 and BLANK heads $1132. maka no sense lol
http://www.flatironstuning.com/m-1-subaru-oem.aspx
I would want a 205/2.0L short block anyways, not a 2.5
Old 03-15-2013, 10:15 AM   #20
wrxlaunch
Member#: 181298
Why not do a 2.5 short block and use 2.0heads? Direct fit and not machine work needed. All u have to do is tune.
wrxlaunch is offline   Reply With Quote
Old 03-15-2013, 10:30 AM   #21
shamrock 05
Member#: 120057
Anytime u strap on old heads to a new block u should have them machined to insure correct fitment.
And the whole hybrid set up....idk, seems like a 2.0L would be easier cause all my parts would transfer over.
So anyone know of anywhere to find a good deal on a 205/2.0L short block?
Wish u could just snag the 2.0 long block lol
Old 03-15-2013, 10:37 AM   #22
greenplates
Member#: 239162
Here is my advice. Do with it what you will ---
Find a smart tuner and bring your motor to him. Sounds like you need some bottom end work. Maybe find a new long block and get rid of that overbuilt / blown up motor.
At least rebuild the blown cylinder, and address the valve issue
greenplates is offline   Reply With Quote
Old 03-15-2013, 11:21 AM   #23
wrxlaunch
Member#: 181298
What parts wld u tranfer over. .. oil pan, heads and ....?
Old 03-15-2013, 11:27 AM   #24
shamrock 05
Member#: 120057
Intake mani, heads....everything I could. I would just like to keep it original and keep up with the 2.0L and slap a 16g on from the get-go
Old 03-15-2013, 02:53 PM   #25
wrxlaunch
Member#: 181298
The same stuff u gonna have to remove from old to install on the new 2.0 shortblock... all that bolts up directly to a 2.5 and u get more trq. You are gonna have to tune with either new 2.0 with your current mods or 2.5 with the same mods and tuning price will be the same regardless of platform.
Just makes sense to go bigger for the same price... same installation process, same bolt ons and needing to tune either way u go. Just my .02
