Old 03-13-2013, 11:24 PM   #1
Vics04sti
Member#: 312032
Default 2013 sti 5 door
Hi guys ! Is it possible to lower ur car a bit without buying an after market suspension or cutting ur springs " like I've heard " ? I just love the way the car feels with the oem ones but would love to see it a bit lowered.... Thanx !
Vics04sti is offline   Reply With Quote
Old 03-13-2013, 11:35 PM   #2
iAmjudge
Member#: 300236
2011 WRX
Fill it with tons of ****.
iAmjudge is offline   Reply With Quote
Old 03-13-2013, 11:48 PM   #3
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Um... put an elliptical from sears in it like I did. Make sure you tie the hatch, it doesn't close.
Serious answer : NEVER CUT YOUR DAMN SPRINGS. If you want low, buy coilovers or some racing / lowering springs. Coilovers are usually more comfortable than racing springs though...
Navendra94 is offline   Reply With Quote
Old 03-14-2013, 01:19 AM   #4
10splaya22
Member#: 283020
2016 Subaru
WRX Limited
You bought a brand new sti and you want to cut your springs? Did i read that right? Go to the suspension sub forum and do some reading. There are plenty of options out there for what you want
10splaya22 is offline   Reply With Quote
Old 03-14-2013, 01:25 AM   #5
Scoobers
Member#: 341693
2013 Subaru
13 WRX SWP
...Playa
Scoobers is offline   Reply With Quote
Old 03-14-2013, 01:28 AM   #6
bondo007man
Member#: 247030
Stop Looking At Me
Swan
My first thought too. Lol
bondo007man is offline   Reply With Quote
Old 03-14-2013, 01:34 AM   #7
bizarro252
Member#: 336417
2008 STi
DONT CUT YOUR (*#%&()&* SPRINGS - EVER
I have not had these on an STi but had them on an integra I had set up as a DD / AUTOX car. Says they lower your car 0.8" and will give you slightly higher spring rates, not enough to make it to rough. The sport line kit is the next step up and lowers it more as well as stiffer rates.
I am not sure if you HAVE to replace your shocks with the pro-lines or not, I did, but you will have to consult an expert
http://www.rallysportdirect.com/Eiba...wering-Springs
Last edited by bizarro252; 03-14-2013 at 01:35 AM. Reason: Linked to the sedan springs, fixed with the 5-door spring link....
bizarro252 is offline   Reply With Quote
Old 03-14-2013, 04:05 AM   #8
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
stock suspension ... NO.
If you cut the springs.. the lord jesus himself will cut you.
DHRDAN is offline   Reply With Quote
Old 03-14-2013, 04:17 AM   #9
henryg
Member#: 334282
2012 STI Sedan
PBP
I have a 2012 sti sedan and I have the eibach pro kit. It lowers 0.8in but looks perfect. No wheel gap AND, believe it or not, rides smoother than stock. Less bouncy and you definitely feel glued to the road. Love Em.
henryg is offline   Reply With Quote
Old 03-14-2013, 05:28 AM   #10
fr0st
Member#: 41618
2008 WRX Hatch
wrb
deflate tires...
fr0st is offline   Reply With Quote
Old 03-14-2013, 05:39 AM   #11
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Search the classifieds for 3 additional donut spares so you will have a matching set of true JDM wheels AND it should be good for an extra inch or two..
p951951951t is offline   Reply With Quote
Old 03-14-2013, 07:11 AM   #12
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
Start dating a fat chick...or dude. Not sure which way your sail blows.
nhmtns is offline   Reply With Quote
Old 03-14-2013, 07:28 AM   #13
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Originally Posted by Navendra94 View Post
If you want low, buy coilovers or some racing springs. Coilovers won't be uncomfortable like racing springs though.
Wut..
Old 03-14-2013, 08:09 AM   #14
Corners
Member#: 346539
Use this lowering kit. It's only $20.
http://kalecoauto.com/index.php?main...products_id=13
Corners is offline   Reply With Quote
Old 03-14-2013, 09:45 AM   #15
Navendra94
Member#: 327495
Plasma Blue
Waste of money... I have a DIY for this, posting writeup now brb.
Old 03-14-2013, 09:47 AM   #16
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You can load up your car until its at the ride height you want, then zip tie your springs so they can't extend once you remove the zip ties.
Old 03-14-2013, 10:51 AM   #17
jhmr
Member#: 313217
2013 STi Sedan Stg 1
Plasma Blue Pearl
Peoples obsession with lowering their cars...
jhmr is offline   Reply With Quote
Old 03-14-2013, 11:38 AM   #18
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Guys I want my car lower but don't want to spend ANY money, how can I ruin my car?
Old 03-14-2013, 12:03 PM   #19
Scoobers
Member#: 341693
2013 Subaru
13 WRX SWP
Subaru WRX STIs have an ESSDC(Electronic Shock and Spring Damper Control) that has to be reset using certain methods. One method puts it into race mode, and your car will think it is at the track and adjust accordingly... kind of like #sport mode in your STi.
Directions to put it into race mode to reset ride height:
1.) Take 1 qt of 10/40 and mix it with sugar (1/2 a cup)-This will form a chain of polysaccharides that react to the 2-2-4 trimethylpentane
2.) Dump it in your gas tank
3.) Redline it until the gas tank is empty
4.) Go fill your gas tank back up
5.) Your ride height will adjust accordingly
Old 03-14-2013, 12:59 PM   #20
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Am I the only one here who knows how to read? The OP is not considering cutting his springs, he's merely asking if there is another way.
Similar example: "I'm too tall, is there anyway to make myself shorter? (without cutting off my feet, or course!)"
-___________-
But for the OP, next time, give your thread a relevant title like: "Can I Lower '13 STI without Aftermarket Suspension?"
blehhh is offline   Reply With Quote
Old 03-14-2013, 02:26 PM   #21
bondo007man
Member#: 247030
Stop Looking At Me
Swan
-___________-
Op cut your springs.
Old 03-14-2013, 05:28 PM   #22
Adamthomas625
Member#: 264401
I believe he mentioned he did not want to cut the springs.. So, no. You did not read that right haha
Adamthomas625 is offline   Reply With Quote
Old 03-14-2013, 06:02 PM   #23
A W
Member#: 265433
Kettle, meet Pot. Pot, meet Kettle.
I'm sure you both must be familiar with each other by now.
A W is offline   Reply With Quote
Old 03-14-2013, 06:11 PM   #24
anonmassive
Member#: 158464
YER MOM
BLURPLE
fat chicks..... done
anonmassive is offline   Reply With Quote
Old 03-14-2013, 07:28 PM   #25
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
I'm still trying to figure out where I can git me some ur springs. Anyone have a link to ur's website?
Nevermind, found it.
http://www.urbandictionary.com/define.php?term=ur
Gallo2011 is offline   Reply With Quote
