Old 03-13-2013, 11:27 PM   #1
westonanderson25
Member#: 348854
Rally Blue
Default boost problems
I have a 2002 impreza wrx and have been having problems. when i accelerate 85 percent of the time i am only getting what seems to be half power and when i get higher in the rpm range i can hear the turbo spooling up and down its not a solid spool like it is spose to. any thing will help thanks
westonanderson25 is offline   Reply With Quote
Old 03-13-2013, 11:34 PM   #2
warpath
Member#: 84622
2016 TR Golf R
1992 MKIII Supra
I got 99 problems but boost ain't one...
Could be a loose intercooler piping coupling. When they get loose or crack you will lose boost.
warpath is offline   Reply With Quote
Old 09-03-2013, 07:43 PM   #3
emphrum26
Member#: 287380
2006 Legacy GT
Brilliant Silver
I am having the same issue on my 05 wrx. I captured a datalog, but I am new to reading them. Hopefully someone could give me some insight?
-Mods-
*Cat-back
*up-pipe
*AP stage 1 91 tune
[IMG][/IMG]
emphrum26 is offline   Reply With Quote
Old 09-03-2013, 09:27 PM   #4
DZXN
Member#: 306186
2002 Subaru WRX
Post a full log on google docs, all we can see from your screen cap is 2k-<3k and that you are missing your right click button on your computer. Set the doc to public and allow everyone to see it.
Read this
http://www.romraider.com/forum/viewt...hp?f=33&t=5384
to help you understand what to log (and not to log Gear, Knock active etc)
DZXN is offline   Reply With Quote
Old 09-04-2013, 02:20 AM   #5
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
a boost gauge will help you, a data log will help us. full boost on an untuned wrx is 13.5psi, on a cobb stage 2 OTS map it's 16psi....just for reference
brew02wrx is offline   Reply With Quote
Old 09-04-2013, 02:23 AM   #6
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
-Mods-
*Cat-back
*up-pipe
*AP stage 1 91 tune
you need to get a better screen of your datalog, do what the above poster said....upload it to google docs and post the link for us to read. However the first thing i noticed is you aren't 100% throttle in your log, you should be...you're at 98%, make sure the pedal is completely to the floor when you get logs. Also take the log doing a pull in 3rd gear with the stock 5 speed.
Old 09-05-2013, 08:45 PM   #7
emphrum26
Member#: 287380
2006 Legacy GT
Brilliant Silver
Thank you for your above input and I will read that link, like I said, I'm rather new to this.
Here is the link to my Google Doc:
https://docs.google.com/spreadsheet/...3c&usp=sharing
As for my throttle position, I was pegged to the ground...maybe this weekend I can post a better log once I read the "how to".
Old 09-05-2013, 11:08 PM   #8
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
-Mods-
*Cat-back
*up-pipe
*AP stage 1 91 tune
[IMG][/IMG]
.... your FLKC is out of control.
Take it to a tuner and check for any lose parts in your engine bay that is causing a knock sound. Your car is removing 10 degrees of timing.
Jubert69 is offline   Reply With Quote
Old 09-05-2013, 11:19 PM   #9
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Your DAM is at zero! It can't go any lower and your ecu is still pulling timing Your log also shows that you are running lean (AF Learning C range at +12 and AF corrections on top of it!). MOST LIKELY YOUR PISTONS ARE SEEING REAL KNOCK. Are you running stock intake or aftermarket?
First do a boost leak test and make sure you don't have any loose or torn hoses.
NO more pulls right now.
nmlittlebigman is offline   Reply With Quote
Old 09-05-2013, 11:23 PM   #10
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
Something loose/rattling around would be seen on feedback knock, I'm pretty sure.
Chicago AJ is offline   Reply With Quote
Old 09-06-2013, 03:55 PM   #11
emphrum26
Member#: 287380
2006 Legacy GT
Brilliant Silver
As far as my intake, its stock. I just put a drop in ait filter in. Sence the log I detuned back to stock map and am boosting normally now. I have checked hoses and found nothing yet. I haven't done a full boost leak check yet
Old 09-06-2013, 07:37 PM   #12
emphrum26
Member#: 287380
2006 Legacy GT
Brilliant Silver
Could this be caused by fuel? This issue started the day after I filled up.
Old 09-06-2013, 07:57 PM   #13
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Yes...but your fuel trims are way off too so that's why I was thinking possible mechanical problem e.g. intake tract leak, dirty or failing maf sensor, bad o2 sensor, fueling system etc.
