Old 03-13-2013, 11:32 PM   #1
STiieed
Member#: 308680
08 STi
Default question answered
Last edited by STiieed; 04-02-2013 at 06:41 PM. Reason: Found answer to my question
STiieed is offline   Reply With Quote
Old 03-13-2013, 11:54 PM   #2
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Get a tune. Don't question, just do. ...or enjoy the $5000 bill when you blow your engine.
+ In fact, you should swap back to the stock airbox ASAP. DO NOT drive around with that intake without a tune. Period.
RoadKillDMD is offline   Reply With Quote
Old 03-14-2013, 12:09 AM   #3
cali_subi
Member#: 346238
maybe you created a leakage in your hot piping while your were working on the CAI ?
cali_subi is offline   Reply With Quote
Old 03-14-2013, 12:13 AM   #4
miteemike3
Member#: 338732
2013 WRX
You absolutely NEED a tune.
I'm not sure where you read that it doesn't need a tune, but you'll need a stage 1 tune via either a Cobb Accessport or you could go opensource with a tactrix cable and a torqued performance stage 1 map. Anytime you start playing with aftermarket intake systems (AEM, Cobb, K&N, etc) or exhaust (uppipe, downpipe, headers, etc), you need a tune to adjust for the increased airflow.
miteemike3 is offline   Reply With Quote
Old 03-14-2013, 02:05 AM   #5
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
ahh another one trying to destroy their engine.... whyyyyyy
WaitTheresMore is offline   Reply With Quote
Old 03-14-2013, 04:02 AM   #6
GrumpyPitbull
Member#: 313311
Haha .. this stuff never gets old.
OP, what ever gave you the idea that your intake did not require a tune?
GrumpyPitbull is offline   Reply With Quote
Old 03-14-2013, 06:26 AM   #7
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
What EXACTLY causes alleged engine failures as a result of an intake or downpipe? I know they'll run like crap w/o a tune, but I'd like to know why its described as being dangerous.
Car leaning out @ wot? Boost creep causing a lean condition?
SlimJim8804 is offline   Reply With Quote
Old 03-14-2013, 06:42 AM   #8
STiieed
Member#: 308680
08 STi
Thanks for all the useful information and advice. Everyone else may go and lerk somewhere else. The car is NOT my daily so no im TRYING to blow up my motor. It hasn't ran since the day the intake was installed. As for where I got my rather bunk info on tuning... I read sevreral places including RSD where it was purchased from, saying a tune isnt necessary although it is recommended. Only reason I have not got one is because im waiting on a down pipe. I just wanted to make sure I didn't have a problem somewhere else.
So to answer my question, its not unusual my car is running like this with a lack of tune?
Old 03-14-2013, 06:54 AM   #9
STiieed
Member#: 308680
08 STi
Double post.
Old 03-14-2013, 09:00 AM   #10
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
When you add a intake on the newer cars it will make them run lean under boost because the maf is not scaled for the extra air that is coming into the engine and it will not add any extra fuel to compensate. Also if you are running the stock tune that is already super lean when going wot it will just make your car go boom boom.
nate_fisher is offline   Reply With Quote
Old 03-14-2013, 09:01 AM   #11
nate_fisher
Member#: 270482
2011 turbotek fxt
Also if the car has not ran since the day you installed the intake how do you know it is running rough?
Old 03-14-2013, 11:49 AM   #12
STiieed
Member#: 308680
08 STi
I installed it drove it around town for a bit then it was parked and has sat since then
Old 03-14-2013, 12:07 PM   #13
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
ON RSD, and all other websites selling that product, they simply copy and paste what the manufactuer says, aka the product description.
While in real life, with actual research and findings, REAL TUNERS have said any 08+ intake NEEDS A TUNE. Simple.
Research "MAF Scaling" for the few that wonder why intakes need tunes.
Old 03-14-2013, 01:47 PM   #14
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
The thread title immediately made me chuckle. The second sentence sealed the deal.
sc00ter is offline   Reply With Quote
Old 03-14-2013, 01:59 PM   #15
Tripintaz
Member#: 245218
2013 STI Limited
Although it doesn't call for a tune my car is really lopey during idle and a few days ago threw a cel.
Let me guess, you don't even know what the CEL was for do you?
Get a tune before you break something.
Tripintaz is offline   Reply With Quote
Old 03-14-2013, 04:01 PM   #16
STiieed
Member#: 308680
08 STi
Thanks for the help to everyone who gave me a mature answer to my question. To everyone else, I feel bad for you. Deeply sorry for your misrable lives.
Old 03-14-2013, 04:14 PM   #17
littlewhitewagon
Member#: 103068
11 STI sedan
AEM intake on it's own does not REQUIRE a tune. Install a wideband to compare side by side and you'll see. Monitor your learning numbers and you'll see the same. Will it run better with a tune? Yes. Will you blow it up without, I doubt any different than the stock tune that blows and can blow up an engine the same.
Too much conjecture and interwebs misinformation.
The car should not drive poorly with a properly installed intake, something is wrong. Check to see that the MAF is seated properly, in the right orientation, all pins seated well.
littlewhitewagon is offline   Reply With Quote
