Old 07-23-2013, 05:54 PM   #1
jpnovak
Member#: 221948
1975 Porsche 914 TT
Default Vehicle Speed Sensor (VSS) waveform?
I swapped a ej20TT and 5MT into my 1975 Porsche 914. Its running Megasquirt and boosting quite happily to 18psi. The car was built on the cheap and competed in the GrassRoots Motorsports Magazine $2011 Challenge. Unfortunately the original motor spun a few bearings due to oiling issues. That is all fixed. It will go back again this year and will be my track car for a while. Now its time to finish sorting the details on the installation.
I need a speedometer. I am currently running a temporary bicycle computer running a magnet off the CV joint. Worked to pass inspection but not optimal.
I want to run a later Porsche speedometer in the dash. These should have a >5V input with 8 pulses per revolution. Its just a reed switch with a magnetic disc in the transmission.
Can anyone tell me what the waveform is from the 5MT? Its circa 1998-99. I only have electronic outputs from the transmission. No cable drive on this one.
I need to know if I can just do voltage conversion or if I have to convert the signal via PWM correction or duty cycle for accuracy. Thanks
jpnovak is offline   Reply With Quote
Old 07-23-2013, 10:48 PM   #2
Teryn It Up
Member#: 225919
2000 2.5rs
Psh... F Kartboy brackets
I found a schematic that shows its a hall sensor that generates 4 pules per revolution. square wave form. It looks like the power is 12v. Schematic just says it comes from ignition. So I am assuming its 12v. Someone will need to verify this for me.
Teryn It Up is offline   Reply With Quote
Old 07-23-2013, 11:04 PM   #3
jpnovak
Member#: 221948
1975 Porsche 914 TT
Thanks, I will probably just put the scope on it while the car is in the air and read the signal from the sensor.
