Old 03-14-2013, 10:38 PM   #1
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Default How long did your performance clutch last?
Just curious as to what kind of mileage guys get out of their performance clutches. Obviously there are way too many factors from car to car so individual results will vary.
Personally, I've gotten like 30 or 40k out of mine. Not sure exactly how many. It is a ppg set up with an act 6 puck. I dont know if that is considered good or bad. My car is a daily driver and makes about 400 wheel on pump gas. I rarely beat on the car and it has never seen the track. I cant stress enough how conservatively I drive my car day to day. It gets boosted like once a week and I dont even run through the gears.
I am 100 percent over my car and cant believe how much money I wasted on her and am cringing at the fact I need to put another 1400 into it.
Thanks for any insight you an provide.
godforbid67 is offline   Reply With Quote
Old 03-14-2013, 10:40 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
ohhhh, and the car has shown 0 signs of slipping until I got in the other day and the clutch pedal is as light as a feather and catches at the highest point possible.
Old 03-16-2013, 09:39 PM   #3
danbolsom
Member#: 256898
2011 WRX Limited 6MT
World Rally Blue
So far i have about 25,000 on my act xtreme duty street disk my buddy had 60,000 on his still going strong
danbolsom is offline   Reply With Quote
Old 03-20-2013, 05:29 PM   #4
godforbid67
Member#: 137168
06 Built SGM WRX
I got a new one installed but now my car will not idle, and the speedo is not working.
Loose hose for the stalling? Or could it be because the battery was off for so long its not relearning the proper tuned map?
And the speedo issue? Could the wiring just be loose on the transmission ? Where exactly is the speedo sensor?
Old 03-20-2013, 11:37 PM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
The answer is YES....there is no answer. Do you need a new one? Read under my username and send me a PM with a hot chick....I'll set you up right with a super cheap and bitchin' clutch that is now the go to brand by the guy who built your transmission.
