Old 04-29-2014, 05:31 PM   #376
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Originally Posted by manitou View Post
How's that gap with 93?
Can't say from experience... it might be a bit tight for gas.
Are you running step colder plugs or stock heat range?
I've found that colder plugs don't work well with E85. The problem is you might need them for making higher power on 93... another reason why we just keep our cars on E85 all the time.
Justin and I also went to higher compression (9:1) on our new builds so we are pretty well committed to Ethanol.
WRXt4cy is offline   Reply With Quote
Old 04-30-2014, 05:38 AM   #377
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by WRXt4cy View Post
Can't say from experience... it might be a bit tight for gas. Are you running step colder plugs or stock heat range? I've found that colder plugs don't work well with E85. The problem is you might need them for making higher power on 93... another reason why we just keep our cars on E85 all the time. Justin and I also went to higher compression (9:1) on our new builds so we are pretty well committed to Ethanol.
I'm using 1 step colder. Yeah I might have to find a happy compromise for the 2 fuels, maybe stock heat range gapped smaller will work. I'm hopefully going to change plugs today so well see.
Old 04-30-2014, 09:52 AM   #378
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
I went from stock to .020 ( recommended was .025 - .022 but I didn't have that on my gapping tool, it was a cheapo from the parts store.)
we really need a good set of aftermarket Coils, the Okada ones leave a lot to be desired, I had a set once and wasnt impressed.
I am working with a huge ignition parts manufacturer to get us some stay tuned!
jnorth85 is offline   Reply With Quote
Old 04-30-2014, 10:17 AM   #379
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
That reminds me, in some roms, there is a table defined called Ignition Dwell that controls the charge time for the coil packs. Increasing this a bit should create a bit stronger spark so it might be worth experimenting with a bit to see if it helps.
Old 04-30-2014, 10:34 AM   #380
manitou
Member#: 193757
2006 XTI Limited
What do you think, should I go with stock heat range and a .022-.024? I know you're not burning 93 pump gas but I'm wondering if the stock heat plugs and smaller gap would work with 93.
I'd welcome anyone's comments here on the spark blowout I'm seeing w/ e85 at 28-29 psi.
Old 04-30-2014, 10:49 AM   #381
jnorth85
Member#: 76785
SRP
Thats what I would do, set the plugs for the higher power/ higher boost tune. your pump tune map is likely a lot less aggressive and could be tuned more conservatively to account for the stock heat range smaller gap plugs.
Ive also read that going to a copper plug can help too, they have a larger spark but they also wear very fast so you'd be changing plugs regularly.
Old 04-30-2014, 11:02 AM   #382
manitou
Member#: 193757
2006 XTI Limited
Thats what I would do, set the plugs for the higher power/ higher boost tune. your pump tune map is likely a lot less aggressive and could be tuned more conservatively to account for the stock heat range smaller gap plugs. Ive also read that going to a copper plug can help too, they have a larger spark but they also wear very fast so you'd be changing plugs regularly.
There's no problem with the spark blowout when the plugs are new and gapped a bit wider like .026-28 but after 5k+ miles or so I see this issue. The plugs in there now were in all winter while in storage. It was started every week but just idled up to temp and shut down. I'm sure that's not great for them either.
I discussed the Brisk with Dom and Junior and both said there not the best for a DD, race car is another story.
Old 04-30-2014, 11:03 AM   #383
manitou
Member#: 193757
2006 XTI Limited
This should be good to look into. Thanks!
Old 04-30-2014, 11:44 AM   #384
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Stock heat range. Coppers. Gap down. Replace frequently.
xluben is offline   Reply With Quote
Old 04-30-2014, 01:14 PM   #385
vinny.dtw
Member#: 139718
2011 STi, E85 1.5xtr
WRB, Show and a little GO
Sexy, schmexy.
vinny.dtw is offline   Reply With Quote
Old 04-30-2014, 01:42 PM   #386
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by vinny.dtw View Post
Sexy, schmexy.
Vince you dog! Lol I've got the black tail lights on it now....Really sexy!
Old 04-30-2014, 01:58 PM   #387
DisoDisp
Member#: 187648
2007 WRX
I run one step colder NGK iridiums gapped down to 0.6mm, pulls like a champ up to 32psi on E85. (haven't tried more boost yet)
Did the whole copper plug thing for a while, but they only seemed to last around 7-10k km till they were ready for a change
Might try some NGK Racing Iridiums next to see if the tiny ground strap would help with pre-ignition, but they cost a ****load.
DisoDisp is offline   Reply With Quote
Old 04-30-2014, 03:56 PM   #388
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by DisoDisp View Post
I run one step colder NGK iridiums gapped down to 0.6mm, pulls like a champ up to 32psi on E85. (haven't tried more boost yet) Did the whole copper plug thing for a while, but they only seemed to last around 7-10k km till they were ready for a change Might try some NGK Racing Iridiums next to see if the tiny ground strap would help with pre-ignition, but they cost a ****load.
Thanks for the recommendation. .6mm is .02358"
I see a definite trend here!
Old 05-03-2014, 02:35 PM   #389
ForesterXT05
Member#: 230019
2006 Legacy GT Spec
full of win!!
ForesterXT05 is offline   Reply With Quote
Old 06-29-2014, 08:51 AM   #390
LesBianJr
Member#: 194550
Yo Dude.......Wassup? Have you been enjoying cruising in the Foz? It's my work season out this way so not much action other than me hitting a cruise night on Tuesday nights. The front of your car looks great with those projector headlights. I attached a vid of the back of my new wagon. I cannot wait for Drag Week in September. https://www.youtube.com/watch?v=rNbf...ature=youtu.be
Be safe my Forester Friend!
Got her out on the road for the first time today! It felt good driving my XTI again after a 6 month hiatus! I filled he up with some fresh E85. Tomorrow I'll change the oil and wash her down and go over the car.
LesBianJr is offline   Reply With Quote
Old 06-29-2014, 03:45 PM   #391
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I've talked about those plugs forever ran them in my dirtbike for years by never found a part number for our cars. What do you have for the part #?
spoolinsti05 is offline   Reply With Quote
Old 07-30-2014, 06:12 PM   #392
manitou
Member#: 193757
2006 XTI Limited
I'm sad to say the XTI is gone. I've been procrastinating this post for quite a while. It was totaled and we're parting it out. Layvon is handling the part out for me.
Please don't ask for details or any photos! It's a big setback for me in the Subaru world and I'm done for now. I built this car over a 5 year period, a steady but somewhat slow progression. I had it pretty much done besides a few minor tweaks and I was actually talking about selling it as I had some unsolicited interest in whether I would consider selling it. I think I set some new standards especially for Foresters and I truly loved driving it, **** it had 143K on the chassis but there was no way you could tell that other than the odometer.
I'm sorry to deliver this post but it's only a car and no one was hurt! That's the most important thing!
I appreciate all the support from this community, so thank you for that!!
Old 07-30-2014, 06:42 PM   #393
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Damn shame. What are plans for a replacement? GTR?
Old 07-30-2014, 08:00 PM   #394
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
The bold is all that really matters, sorry to hear the car was not as lucky.
Scuby04STi is offline   Reply With Quote
Old 07-30-2014, 08:20 PM   #395
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
sorry about your car, I am glad you are ok
Old 07-30-2014, 10:52 PM   #396
uglybetty
Member#: 381907
2005 forester STI
Sorry to hear dude. Your build and insight on sfo has been a great inspiration and guide for the big turbo foz I'm putting together.
uglybetty is offline   Reply With Quote
Old 07-31-2014, 08:36 AM   #397
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
So sorry to hear about the foz but gear that nobody was hurt!!
Steve.804 is offline   Reply With Quote
Old 07-31-2014, 09:17 AM   #398
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Noooo!! Man, so sorry to hear about the XTi. Glad you're alright.
wgr73 is offline   Reply With Quote
Old 08-01-2014, 03:00 PM   #399
manitou
Member#: 193757
2006 XTI Limited
Thanks for the note and concern Greg! Now you know why I didn't reply to your post! Yep it sucks!
Old 08-01-2014, 03:03 PM   #400
manitou
Member#: 193757
2006 XTI Limited
Thanks guys! The ****ing car was a tank!! Not a scratch and the airbags didn't even deploy. No replacement plans at this point. I've got to give this whole thing some time and I'm not sure I want another automotive $$ black hole if you know what I mean! It was a pretty fun car and I did'nt cut many corners on this build. I just couldn't see trying to replicate what I had done over the 5 years time.
