03-30-2013, 02:41 PM | #101 |
Member#: 64908
Vehicle:10.8 XT+9.2@155 GR+ 9.1/157mph 2015 STI |
No training needed, the throttle map is setup to compensate for the driver
03-30-2013, 04:41 PM | #102 | |
Member#: 103631
Vehicle:2004 STI Gray |
I then moved to the air atomizing nozzle type making it fully mechanical. It's basically like an HVLP gun, using pressurized water on one side of the nozzle and air on the other side to disperse the mixture into a fine mist. The spool decreased. I have logs of it on and off--spool reduced by both time and RPM. Wet compression increases the efficiency of the compressor slightly, and you get the benefit of detonation resistance from the water as well. It's just more finicky with the amount of injection, placement and water droplet size. http://www.rx7club.com/auxiliary-inj...esults-987107/ I saw the same effect of this user here with the traditional pump and nozzle. I think the reason why these tests show reduced spool is that the progressive nature of the water injection has poor atomization till the high point, and then as the atomization increases, the turbo shaft speed accelerates normally. Spool suffers as the larger droplets slow the rpm of the compressor. You can see the effect of the increased top end with no tuning though. I actually use 50/50 as it helps with atomization--alcohol is less dense and thus helps the atomization and cooling further, but I feel like the increases are all over the curve. You'll also notice that the post intercooler injection didn't raise power without tuning, but we all know that in the hands of a good tuner, power can go up. I'm sure that with an Aquamist kit, which has constant pressure at low flow, and thus the same atomization at low and high, you would see similar results to the air atomizing nozzle. I just like that it's mechanical and simple. For your setup, I would just be worried about nozzle placement, as you want to mount the air atomizing nozzle close the compressor. Wet compression works on a different principles than traditionally mounted water injection. Theoretically wet compression would have the greatest effect on turbos at the edge of the efficiency island, but I would argue that it can help any turbo. I can feel an increase in torque when it kicks on. PM me and I can show you pics of my install. Don't want to ruin your thread. Last edited by reid-o; 03-30-2013 at 04:48 PM. |
03-30-2013, 04:46 PM | #103 |
Member#: 190729
NWIC
03-30-2013, 06:27 PM | #104 |
Member#: 195711
Vehicle:PART OUT. PM ME 02-07 Goodies |
Now that he has FFS set up, it shouldn't be an issue should it?
03-30-2013, 08:48 PM | #105 |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned 573WHP |
I did totally forget to set up the LC and FFS after I got back in the XTI from a 2 week leave! We (my buddy Alex and I) were doing the launches at a 6K setting and I have the FFS at 7500.
I did a couple road pulls last night and was more cognoscente of not over revving it. Jr, you told me to keep it under 7500 but it's hard. Even my bud Alex said my car revs sooo easily it kind of surprised him! Jr, I want you to tune Alex's STI, he was the guy I was telling you about and after driving my XTI he's like.....sign me up. We'll be in touch! |
04-01-2013, 08:25 PM | #106 | |
Member#: 193757
From Xluben's thread:
We'll be working refining the driveline a bit and swapping in my Feal refreshed Ohlins with some tweaks on the front suspension bits and alignment. Also working on the launch, it's feeling pretty good and hooks up very well with my big Conti's which aren't very sticky. I did find an issue that I think was caused from my battery going dead while I was away from the car for 2 weeks. When I made those video clips the other night, I was not at full power. I re-set the ECU and voila full power back, after that we were working on the launches and that video on Friday. I ran a couple logs running through gears from a 20-30 roll and from the not so accurate AP elapsed time 50-100 looks like around 4+ seconds. Take that with a grain of salt because I don't think the time is accurate! Last edited by manitou; 04-02-2013 at 06:55 AM. |
04-03-2013, 02:30 AM | #107 |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
Dude, I finally got a chance to check out your thread on a computer that displays pictures. This ride is clean and delivers the goods. I'm really digging that exhaust and intake setup. Excellent excecution and results.
04-03-2013, 08:39 AM | #108 |
Member#: 193757
Thanks Kelly! I like it too! It sure is fun to drive and it's been on E85 for 3 weeks now. I'll be swapping back to the pump gas map in a day or so and taking her on a working road trip this weekend. Is MPS building your new motor now and when will it be done?
04-03-2013, 11:01 AM | #109 |
Member#: 32669
SCIC
I sent Dom my old block for him to begine sleeving. When that's done I'll be sending him everything else need to assemble the longblock. I'm in no hurry though, my current motor is entertaining enough right now but I think I may be having tranny or front diff issues.
04-03-2013, 11:19 AM | #110 |
Member#: 193757
Bummer on the tranny diff stuff, what's going on?
04-03-2013, 12:04 PM | #111 |
Member#: 277487
NWIC
Vehicle:2006 CGM WRX Limited 6sp, 18G, Phatron tuned |
LOVE this car!!!
04-03-2013, 12:18 PM | #112 |
Member#: 32669
SCIC
I've always suspected something ever since I got the car but since I never really drove it hard or had any power behind it wasn't a problem. When I first bought the car I noticed a binding issue making tight turns but a tranny fluid change helped that out to some extent. I did a 4400 rpm launch with a buddy in the car the other day and the car didn't go anywhere. No burnt clutch smell and I wasn't spinning my wheels in place but I stayed in it and gradually started pulling away. I shift to second and bogged since I had almost no ground speed then drive off normally. I also get clunking when getting into power or lifting sometimes and making tight turns. I used to drive with DCCD set full rear for this reason. How do you troubleshoot front and center diff issues? |
04-03-2013, 01:00 PM | #113 | |
Member#: 193757
You should have no binding unlocked in either full front or full rear. You should have binding locked full to the front but not full to the rear. If you have no binding at all full to the rear and you do have binding full to front locked, you could probably rule out the center diff. If you have some binding full front unlocked then the front diff may be bad. |
04-05-2013, 10:00 AM | #114 | |
Member#: 193757
I'm launching at 6k on my tall 245/45-18 Conti's and my buddy Alex launches his built STI with DSS axle bar upgrades and carbon drive shaft at 7k. He also runs BFG drag radials and they hook pretty hard! On another note I ordered my Drive Shaft Shop carbon drive shaft and front and rear axle bar upgrades yesterday!! Yippee! I'll swap those in along with my Feal re- built Ohlins FPS and custom (by me) 1/2" front top hat spacers when the DSS stuff shows up! |
04-05-2013, 10:24 AM | #115 |
Member#: 32669
SCIC
I don't have LC setup yet and I've been launching manually. I've only launched it about 5 times actually and all have been between 4000- 5000 rpm and I've only bogged once at that rpm so far and cut my best of 1.7X 60 ft. I could do better with a higher rpm launch but my diffs already don't like the 4400 rpm launches. I make peak torque at 3500 rpm then its flat all the way out to redline so as long as I stay in the gas there is usually no bogging.
04-05-2013, 10:45 AM | #116 | |
Member#: 193757
04-05-2013, 11:31 AM | #117 |
Member#: 32669
SCIC
All the dyno graphs, VD, and my VE fuel map all show peak torque around 3500 rpm. I'm sure if I cranked the boost up I could get it to rise and peak later but right now I'm not even pushing the turbo or the motor.
04-05-2013, 11:56 AM | #118 |
Member#: 193757
04-05-2013, 12:07 PM | #119 |
Member#: 32669
SCIC
All runs where done in either 3rd or 4th but even a run in 1st should have the same general shape right? I guess I'll have to do a pull and see.
04-05-2013, 12:10 PM | #120 |
Member#: 193757
04-05-2013, 01:11 PM | #121 |
Member#: 32669
SCIC
Does airboy have the gear ratio data if I pulled a first gear log?
04-05-2013, 01:17 PM | #122 |
Member#: 193757
04-07-2013, 01:08 AM | #123 |
Member#: 283134
Vehicle:2015 STi LE EFR7163 500whp/550wtq |
Did this FXT start as an auto, or manual? I sent you an email about the swap details, I absolutely LOVE FXTi's!
04-07-2013, 01:20 AM | #124 |
Member#: 193757
04-07-2013, 07:46 AM | #125 |
Member#: 193757
