Old 03-14-2013, 10:50 PM   #1
Artizle
Member#: 251825
2004 WRX
Default Exhaust Gas question
When a car is experiencing full boost does the majority of the exhaust gas exit through the wastegate?
Artizle is offline   Reply With Quote
Old 03-14-2013, 10:54 PM   #2
nismopowerdqg
Member#: 312580
2010 WRX [email protected]/334
Cobb/Torqued Performance
The internal wastegate is roughly the size of a quater. So think about it..
nismopowerdqg is offline   Reply With Quote
Old 03-14-2013, 11:50 PM   #3
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
If you unhook your WG actuator and let the flapper hang open you make no positive pressure so during full boost it can't be opening very far or you would loose a ton of pressure.
lukeskywrx is offline   Reply With Quote
Old 03-15-2013, 10:57 AM   #4
van_dutch
Member#: 198633
2004 WRX
The wastegate's function is to limit boost by bypassing the turbine and thus slowing the turbo's rotation.
van_dutch is offline   Reply With Quote
