Old 02-21-2013, 11:55 AM   #1
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Default 4EAT Sloppiness......AT guru's please chime in !
Pretty vague thread title huh..
Mods..16G and all supporting.
Big tranny cooler and regularly changed Amsoil ATF
I've noticed over the past several months some (what I can only consider as) sloppiness. No slippage under acceleration or anything.
There are some clunks when shifting from park to REV, some "wobbly sloppiness" when lifting off throttle while cruising in traffic...that sort of stuff.
The trans shifts fine through all the gears, it just doesn't feel very "tight" which I can probably attribute to the higher than stock HP and TQ.
I don't beat on it, but its right around 104K and am wondering if there are any remedies.
Center diff?
Driveshaft U-joints?
Entire driveshaft?
Muffler bearings?
Tightening (or maybe loosening) the nut behind the wheel?
Any ideas on this one?
Brock31 is offline   Reply With Quote
Old 02-21-2013, 12:04 PM   #2
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Honestly I just think the transmission is normally wearing. As more debris gets into the valve body and passages, and the clutch packs wear down, as with any auto, they start becoming more sloppy.
Old 02-21-2013, 12:05 PM   #3
Strider327
Member#: 131280
2004 Impreza WRX
Do you have any whining noises? I would say the center diff is a good place to start looking. Unless your transmission mount has failed.
Strider327 is offline   Reply With Quote
Old 02-21-2013, 12:10 PM   #4
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
It sounds like a loose or cracking mount to me. Check motor mounts while you're down there.
guroove is offline   Reply With Quote
Old 02-21-2013, 12:20 PM   #5
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Thats a good place to start. I replaced the trans mount bushing a while back with the Rallitek (I think) harder model.
No, I don't have any whining sounds.
When I shift from Park to Drive or Park to REV, there is usually an audible "Clunk". But again, its just a sound that happens once. Most likely a solenoid or something?
Can the driveshaft wear out?
The reason I ask is because, years ago I had a toyota pickup converted into a camper. It had an AT and was really sloppy feeling. One day, one of the U-joints finally gave out and I had the whole DS replaced. It felt like a new truck when I got it back.
Hows that for a completely random and unrelatable comparison!
Old 02-21-2013, 12:54 PM   #6
Strider327
Member#: 131280
2004 Impreza WRX
Well if your driveshaft is indeed fubar, you would know! I'm assuming its mount related. If a solenoid in the valve body failed, you would have rough shifts etc. It's more than likely an external issue than internal.
Old 02-21-2013, 01:02 PM   #7
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
KOJAK-02-WRX is offline   Reply With Quote
Old 02-21-2013, 01:07 PM   #8
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Originally Posted by KOJAK-02-WRX View Post
Yes...let me get out my checkbook. [adjusts monacle]
Maybe one day a built trans, but if I'm going to drop that kind of money, I'd end up going with a 6 speed.
Old 02-21-2013, 01:08 PM   #9
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
OK
So your suggestions are trans mounts and motor mounts?
I'm not even 100% sure how to check the motor mounts? I know they are stock and the only time they have been remothely messed with would have been during UP replacements.
Old 02-21-2013, 03:53 PM   #10
Strider327
Member#: 131280
2004 Impreza WRX
The best thing to do is jack up the car and see if there is movement on the mounts themselves. Or just see if you are able to identify visible cracks or so on the mounts themselves. I'm assuming these are stock and not aftermarket.
Old 02-21-2013, 04:05 PM   #11
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Stock motor mounts yes.
Aftermarket trans mount bushing.
Old 02-22-2013, 12:46 PM   #12
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Any more guru ideas?
Old 02-22-2013, 08:56 PM   #13
Strider327
Member#: 131280
2004 Impreza WRX
If its anything else it would be internal to be honest.
Old 02-25-2013, 08:55 AM   #14
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Still haven't had tome to get under the car
I'll plan to start with checking the mounts, and move on from there.
Old 03-17-2013, 04:12 PM   #15
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
2 things come to mind...front differential
as far as delay in shift...from d to r or p tp r or p to d...internal low clutch issue.
04stigeorge is offline   Reply With Quote
