Welcome to the North American Subaru Impreza Owners Club Saturday August 30, 2014
Old 03-16-2013, 03:03 PM   #1
milocas
Member#: 201641
05 Impreza WRX 2.0
CGM
Default Replace all Vacuum hoses?
Soo i have a 05 WRX and was wondering if it was gonna be worth replacing the vacuum hoses?
I want to get blue hoses to change the black hoses and to also prevent any leaks i might have.. Ive noticed that FASTWRX sells a "Vibrant Silicone Vacuum Hose Kit" for a pretty decent price to me and includes all of the following;
5 ft. of 1/8" (3.2mm) I.D. hose
10 ft. of 5/32" (3.75mm) I.D. hose
4 ft. of 3/16" (4.5mm) I.D. hose
4 ft. of 1/4" (6mm) I.D. hose
2 ft. of 3/8" (10mm) I.D. vacuum hose
Do you think this will be everything i need beside coolant lines and such? I already have the hoses for the TMIC and yet to replace my turbo inlet which i will if this kit includes almost every line. Thanks for your input!
milocas is offline   Reply With Quote
Old 03-18-2013, 06:25 PM   #2
drumrsbangbettr
Member#: 314383
When i put in my new short block in my 02 i did... All of them were stiff and brittle, and many broke during disassembly. Turbo inlet is a great idea too if you're taking the manifold off. The side that goes on the turbo gets pretty fragile with age.
I got all my hoses from https://www.siliconehose.com, including the heater hose. It all cost under 60 with shipping, and i did order more than necessary so i would have extra. I still have the receipt if you want to know the sizes.
Heres how mine looked right after i dropped the motor back in:
drumrsbangbettr is offline   Reply With Quote
Old 03-18-2013, 07:56 PM   #3
milocas
Member#: 201641
05 Impreza WRX 2.0
CGM
If you dont mind pm'ing me the sizes that would be great! and of course the length, Thanks.
Old 03-19-2013, 04:44 PM   #4
tec_41
Member#: 346278
04 WRX
Silicone hoses can save you a ton of headaches down the road...I've been going through mine and can't tell you how many hoses are brittle and cracked. Those all eventually lead to vacuum leaks.
Plus they're super heat resistant. On my last car I ran one right over the hot side of the turbo without any issues. (Not resting on it, obviously)
tec_41 is offline   Reply With Quote
Old 03-19-2013, 05:26 PM   #5
milocas
Member#: 201641
05 Impreza WRX 2.0
CGM
Yeah I think im gonna replace all the hoses and be done with it. Should I do a diy?
Old 03-20-2013, 04:53 PM   #6
Fatnslow
Member#: 314685
2002 WRX Sedan
I am also interested in knowing the sizes of the hoses. It looks great.
Thanks,
Kevin
Fatnslow is offline   Reply With Quote
Old 03-20-2013, 09:33 PM   #7
drumrsbangbettr
Member#: 314383
Heres what i bought:
Vacuum hose:
13mm x 8 feet
6mm x 6 feet
4mm x 8 feet
Heater Hose:
0.31" x 8 Feet
Total = $59 with shipping
If my memory is right you could probably get by with just 6 feet of each diameter vacuum hose. I think the only ones i didn't get there was, the larger one on the upper coolant reservoir and a large one where the pcv system connects to the block (pictured below).
Old 03-21-2013, 07:42 AM   #8
shamrock 05
Member#: 120057
2004 "Bugeye" WRX
You absolutly should post up a detailed DIY sizes and all
I have the Vibrant hose kit (havent installed) but the hoses used for the "breather tubes/black aluminum tubes running infront of the IC" it doesent seem like it supplies you with enough length to do the 3 hoses.
One question I do have is since the outer diameter is bigger on the silicone hoses....should I be using "worm gears" to tighten them down rather than zip ties?
shamrock 05 is offline   Reply With Quote
Old 03-21-2013, 11:08 AM   #9
Fatnslow
Member#: 314685
2002 WRX Sedan
Thanks! Are those numbers for the inner or outer diameter?
Vacuum hose:
13mm x 8 feet
6mm x 6 feet
4mm x 8 feet
Heater Hose:
0.31" x 8 Feet
Old 03-21-2013, 09:51 PM   #10
drumrsbangbettr
Member#: 314383
Yes you should. The hose that goes to the the overflow tank isn't pressurized though and doesn't require a clamp. I just put zip ties on for good measure.
Inside diameter.
Old 03-22-2013, 01:06 AM   #11
milocas
Member#: 201641
05 Impreza WRX 2.0
CGM
Should be ordering the hoses soon. Ill try my best to make a DIY than for people.
Old 03-22-2013, 02:41 PM   #12
3dbello
Member#: 318602
2003 WRX Wagon
When I changed all of my hoses to Silicone I noticed slightly better throttle response and improved gas milage. This is the kit I ordered and it's great.
http://www.ebay.com/itm/Mishimoto-Si...item35bed8c282
3dbello is offline   Reply With Quote
Old 03-25-2013, 03:10 PM   #13
shamrock 05
Member#: 120057
2004 "Bugeye" WRX
I bought the Vibrant hose kit, but the problem I am going to have is knowing which oem vac line is which size
Old 06-08-2013, 12:46 AM   #14
runboyrun
Member#: 287901
2003 WRX Wagon
has anyone completed this with the Vibrant Kit? Does it replace every line?
runboyrun is online now   Reply With Quote
Old 06-08-2013, 08:48 AM   #15
milocas
Member#: 201641
05 Impreza WRX 2.0
CGM
I haven't done it yet due to not having time. But from ive been reading online its best to buy all the hoses separate. Just because people been sauing that the kit gives us less of amount hoses to make it work complete as a plug and play.
If you guys want ill go out and buy all of the hoses I might need and do a how to since my car is currently apart at this moment.
Old 06-08-2013, 09:19 AM   #16
Jenovuh
Member#: 332990
2005 Impreza WRX STi
A how to would rock!!
Jenovuh is offline   Reply With Quote
Old 06-10-2013, 02:01 PM   #17
runboyrun
Member#: 287901
2003 WRX Wagon
This! It's hard to get all the right sizes to buy in bulk.
