Old 03-16-2013, 04:15 PM   #1
Ethanwrxwagon
Member#: 270948
2005 wrx wagon
Default 4EAT 4.11 Front diff into 5MT
I drive an 05 4EAT WRX, i just purchased a 02 WRX 5MT with blown second and plan on buying a LGT gearset rebuild kit for 02 WRX to put in.
My question is with having 4.11 final drives in the 4EAT and a 3.90 front diff in the 5MT is it possible to pull the 4EAT 4.11 and put it in the 5MT? i dont know yet if ill need a new Cluster shaft for the LGT kit or not (i would assume i would)
IIRC LGT's final drive is 4.111 would that clustershaft mesh properly to a 4.11?
I looked at the stickies and couldnt find what i was looking for.
Excuse my ignorance.
Ethanwrxwagon is offline   Reply With Quote
Old 03-16-2013, 04:33 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Only problem is you would have to also swap out the transfer gears on the tail end of the tranny. The 02-05 wrx 5 speed has a 1.1:1 transfer gear set just before the rear driveshaft. Which is why the rear diff is a 3.545 ratio and the front is a 3.90
~Josh~
Old 03-16-2013, 05:45 PM   #3
Ethanwrxwagon
Member#: 270948
2005 wrx wagon
but would i have to find a different driveshaft? i dont have any of the extension/tail housings or any of their guts so that would be fine.
youre saying i would have to get an LGT's transfer gears?
Old 03-16-2013, 08:39 PM   #4
subi400
Member#: 216984
1996 Impreza outback
Green
He is saying that you would have to get the transfer gears from a tranny tail section that has a 1:1 so you can have the 4.11 front and rear diff ratio.
The auto drive shaft is shorter than a manual one so you will have to find a manual drive shaft.
subi400 is offline   Reply With Quote
Old 03-16-2013, 08:51 PM   #5
Ethanwrxwagon
Member#: 270948
2005 wrx wagon
I know i need another drive shaft. What cars used the 1:1 transfer gears? Legacy? So just get an LGT cluster shaft and transfer gears and i should be good?
