Old 03-17-2013, 12:41 PM   #1
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Default overboosting concerns?
Hey fellas need some info first time wrx buyer and having alot of problems so far.
Car currently has
cobb bov
spt exhaust
invidia down pipe (catted with bracket to conform exhaust)
cobb intake and box
turbo heat shield
and cobb ap running acn91 stage 2 sf (super low waste gate)
im change map after map and im still overboosting i do the live data log and i overboost in 4th gear and 19.1 pounds and stay overboosting in 5th gear around 18.5 to 19.5 the whole time
i have all the parts that the guys have recommended and i know of people who have the exact same parts and running the ap map and not even close to overboosting the only difference is my bov (to my knowledge its installed correctly )
is it possible that just my bov is causing all these issues
20satinwhitebeast13 is offline   Reply With Quote
Old 03-17-2013, 01:21 PM   #2
jaboyd
Member#: 247304
2011 STI
WR Blue
Car currently has
cobb bov
spt exhaust
cobb intake and box
turbo heat shield
I have a 2011 with Invidia Q300 catless dp, stock BOV , stock airbox. When I used the AP OTS maps and a COBB CIA I was getting boost creep in colder temps. I changed back to stock airbox and immediately dropped 1.5 to 2 psi. I had an e-tune done and the car no longer gets boost creep and runs great (plus its a little quieter).
The combination of CIA and catless DP is a known problem combination. You might try just going back to the stk air box and a Stage II tune to see if that takes care of it. By the way if you running the Cobb stage II + map and std WG settings you should be right around 19psi. If you're getting an initial spike of 19.5 psi but it falls back to 18.5 - 19 psi you should be ok.
The friends of mine that ran the Cobb BOV found that it had a tendency to have driveability issues and other than making noise did nothing for the performance...FYI.
jaboyd is offline   Reply With Quote
Old 03-17-2013, 06:01 PM   #3
sc00by4life
Member#: 97135
let me guess, you're doing low RPM full throttle pulls arent you?
overboosting is extremely common in that scenario, and something you should AVOID as it is not good for the motor.
Old 03-17-2013, 07:01 PM   #4
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Can u explain that better
Old 03-17-2013, 08:57 PM   #5
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
You need to take a WOT datalog to know what is going on. Select the default AP datalog parameters and include TD Boost Error if it is not already selected.
jebjkey is offline   Reply With Quote
Old 03-17-2013, 09:09 PM   #6
Tyrus3
Member#: 133875
2000 Impreza RSTi
2005 Legacy Wagon
I think he's trying to advise avoiding wide open throttle when you're at ~2k rpm's and less, which is good advice. Only go WOT, which you'll need to to pull good data, when you already above 2k rpm...and can safely go WOT.
edit, post your log data in the AP forum too to get better visibility for the data.
http://forums.nasioc.com/forums/forumdisplay.php?f=140
Tyrus3 is offline   Reply With Quote
Old 03-25-2013, 11:26 PM   #7
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
So I had bought the grimspeed uppipe to finally fix my overboosting after all the research the Grimm seemed to be the best one but is there any downsides to this purchase ?
Old 03-25-2013, 11:40 PM   #8
jebjkey
Member#: 73884
16 HyperBlue STi
How is the UP going to fix overboosting?
Old 03-25-2013, 11:48 PM   #9
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
On the the thread on overboosting it clearly gets into detail about how the upgraded uppipe controls the airflow reducing boost creep is that wrong ?
Old 03-25-2013, 11:59 PM   #10
M///Scooby
Member#: 28117
2012 WRX
What most do is get the up-pipe WITH a flange for an EWG. The reason for boost creep is because the turbo cannot flow enough gases though the WG to control boost, thus experiencing boost creep. With an up-pipe and EWG, you flow more air through the WG to control boost, thus eliminating boost creep.
M///Scooby is offline   Reply With Quote
Old 03-26-2013, 12:07 AM   #11
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
I'm sorry I feel like I'm beating a dead horse so with just an uppipe am I fixing anything at all
Old 03-26-2013, 12:25 AM   #12
Heedlessone
Member#: 254130
1993 LS1 RX7
No, probably not. You can either port your stock wastegate, or get an EWG.
Heedlessone is offline   Reply With Quote
Old 03-26-2013, 06:34 AM   #13
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
No, you MAY see a slight increase in spool respone but that is about it unless you are going EWG.
Old 03-26-2013, 07:06 AM   #14
GrumpyPitbull
Member#: 313311
On the WRX, you should be doing your pulls in 3rd gear ... not 4th or 5th. I included a link to Cobbs datalogging video, check it out and log it again properly using the severe low wastegate map and see where your at.
If your still having issues, call Cobb and run your questions by them. They are pretty good about helping people out with issues on their OTS tunes.
GrumpyPitbull is offline   Reply With Quote
Old 03-26-2013, 08:52 AM   #15
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
That sucks lol Iike I need to spend and extra 500 dollars on an ewg fml
Old 03-26-2013, 09:03 AM   #16
GrumpyPitbull
Member#: 313311
I would not be so quick to go ewg with your mods .. its simply not needed.
Old 03-26-2013, 09:16 AM   #17
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
I just can't find another resolution to stop overboosting without removing parts
Old 03-26-2013, 09:18 AM   #18
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Then I can't stop my overboosting without removing parts
Old 03-26-2013, 09:23 AM   #19
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Have you done a log in 3rd gear? Boost can flucuate, just because you are 1-2 psi over once in 5th doesn't mean it's an issue. It honestly read like you've read too far into this and don't have, or know if you have a true problem at this point.
Best way to know, find a local tuner.
Old 03-26-2013, 10:12 AM   #20
GrumpyPitbull
Member#: 313311
That may eventually be the case, but you have been datalogging wrong. View the video I posted, then log the car properly (in 3rd gear, from 2500 rpm to redline) and come back here with the results ... We can go from there.
I'm on my phone, and not looking at Cobb's specs, but I'm going to guess your target boost is 17 or 17.5 (+/- 1psi). At 19, you are only 1 psi overboosting, but that may very well be due to improper logging.
Old 03-26-2013, 10:26 AM   #21
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
It's actually my 4th gear at about 5500 ill log what i can this week. But I am barley hitting 19.5
Old 03-26-2013, 10:30 AM   #22
greenplates
Member#: 239162
Just surprised you bought a stage 2 car as your first Wrx
I strongly believe one of 2 things.....
Your tune is not adjusted appropriately for the parts OR your unnecessary bov/intake combo are causing issues
Since you are new to Wrx, I'm assuming you are new to the Subaru community. Many of the guys on here do not run intake OR bov , for the reasons that you have described
greenplates is offline   Reply With Quote
Old 03-26-2013, 10:41 AM   #23
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Believe me if I wasn't so deep Into parts is I would of stayed stock. I removed the bov already the intake stayed on if I solve all my problems with an ewg uppipe and them getting a pro tune that's all I have left
Old 03-26-2013, 12:31 PM   #24
jm02466
Member#: 282876
05 LGT Limited
04 WRX Wagon
I'm confused. You removed one of the two parts that people are telling you could fix your issue and instead of removing the intake as well, you decide your only option it to add an EWG? Why aren't you trying the stock air box instead of throwing more mods at it?
jm02466 is offline   Reply With Quote
Old 03-26-2013, 12:41 PM   #25
sc00by4life
Member#: 97135
overboosting and boost creep are NOT the same thing!!
