Old 03-17-2013, 06:04 PM   #1
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Default 07'-09' Legacy shortblock with phase I 2.5 DOHC Heads
I've searched a bunch and no specific help.
I have a 07'-09' phase II N/A short block with low low miles and want to put some 97' legacy DOHC heads on it. The thing I'm unsure of is if the pistons will work with those combustion chambers, as they pop up out of the block a little. I'm not worried about the compression too much, but rather if it will interfere or not.
Anybody been down this trail before?
Thanks!
morrocco88 is offline   Reply With Quote
Old 03-24-2013, 07:14 AM   #2
JoshP
Member#: 94350
Are the pistons domed? If so, then no they wont work. You can swap in P1 pistons and that will work.
JoshP is offline   Reply With Quote
Old 03-24-2013, 08:35 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The EJ25D pistons also protruded from the deck, too, but only by 0.05mm (which was less than the head gasket thickness by quite a bit).
How does the '07-09 compare to that?
Old 03-25-2013, 02:00 PM   #4
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
They seem to pop out past the Deck quite a ways. I've been told by another source that it will not work.
I just picked up a 99' Forester with a phase II EJ25 (spun bearing) with 53K original miles. If the heads look good, I might just use it for that....asuming it will work with those heads?
Old 03-25-2013, 02:47 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
They'll hit. The newer 2.5i pistons are way too domed.
Old 03-25-2013, 10:32 PM   #6
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Do you think it will work on a 99' forester with the first of the phaseII motors?
Old 03-26-2013, 12:42 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yes. There are plenty of examples of folks using the DOHC heads on the '99-05(ish) Phase II blocks, myself included.
Old 04-21-2013, 12:33 PM   #8
JoshP
Member#: 94350
Pat, the pistons dont protude, they are domed and the combustion chamber has a different shape. His '07 shortblock wont work with either set of heads he mentioned. Id be careful just throwing out incorrect info like that...
Heres a pic
Old 04-21-2013, 05:23 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Originally Posted by JoshP View Post
Pat, the pistons don[']t prot[r]ude, they are domed and the combustion chamber has a different shape.
When you say "the pistons", I don't know which ones you're referring to since there have been 3 different short block varieties mentioned in this thread. The OP said the '07-09 pistons protruded from the deck; if you disagree with that information, then correct him. The only statement I made was about the EJ25D pistons, which do protrude 0.05mm from the deck. You can find that information in a variety of places on this forum. The math (courtesy of TWE): 30.3mm piston compression height + 131.25mm rod length + 1/2 the stroke = 201.05mm. Deck height is 201mm.
His '07 shortblock won[']t work with either set of heads he mentioned.
I never said it would. I did say that Phase I DOHC heads will work on an early Phase II block, since the OP asked about using the heads on a '99 Forester short block. Subaru built engines like that in '98 and '99, and I and a number of others have built engines like that.
I[']d be careful just throwing out incorrect info like that...
If you can point out what I said was incorrect, that would be great.
Old 04-21-2013, 06:24 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Let me at those newer pistons with my porting bit. I'll make it work!
FuJi K is online now   Reply With Quote
Old 04-21-2013, 06:57 PM   #11
JoshP
Member#: 94350
a '99 shortblock was never mentioned, only shortblock he ever asked about was the '07. He clearly mentioned that his '99 Forester has a spun bearing... You obviously misread into that post.
Old 04-23-2013, 09:01 PM   #12
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
So the 07' shortblock won't work with the 99' Forester heads either? I'm just about to tear into this project and hoped the 07' block would make it duck soup.
