Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-17-2013, 08:07 PM   #1
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Default fuel gone crazy
Ok guys maybe you can help me. Im no expert tuner but i do know my way around the utec and tuning it. So that being said lets talk fuel.
The car is an 02 wagon it has all the bolt ons for a stage4 car, full mod list below. The car supposedly has modded blues in it. So i loaded up the stage 4 map set everything and the cars idle is way off. It will go as high as 17.7 then drop to 10.0 and just keep doing that. Then it will stay around 13.xx then keep going up and down again. Did a pull and idc went up to 100%. So i made corrections with the scaling but no matter what i cant get them stable. We have changed maf, iac, but nothing. Boost and timing is right on but fuel is crazy. Just for reference i set the stock inj size at 500 and utec at 730, ive tried 420 and 650, and just about everything in between. Ive about came to conclusion that its bad inj. In stock mode the car will not idle well either and runs lean, very lean. Can anyone give some input.
2 side notes
1. Did a pull down low below 4000rpm the car was pig rich and above it would start to level out then go lean by 6k.
2. The stock bcs is not hooked up in anyway. The hallman bc is the only thing controlling boost.
Mod list
Vf39
Tbe brand unknown
Perrin air intake stock size
Modded blues ?
Sti tmic
Txs uppipe
Aftetmarket header brand unknown
Hallman bc that you can control from inside
spoolinred is offline   Reply With Quote
Old 03-17-2013, 10:56 PM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
Idle issue points to either maf or bad inejctor scaling. Pull under boost shows massive boostleak/bad injector scaling. Set oem inj size to 420 and new size to 800. If they are modded stocks they are flowing around that.
sidewayz is offline   Reply With Quote
Old 03-17-2013, 11:14 PM   #3
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Ok thanks i will try that, if not that i have another set i can try.
This is my buddies car which he just got a few weeks ago. He is the third owner. The previous owner claims it had been tuned. But didnt know what was used bc to tune it. But it would have to of been opensource. If the car was tuned with opensource should the car be flashed back to stock or would it matter?
Old 03-18-2013, 01:45 PM   #4
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Yes the car should be flashed back to stock if you want to use the utec to tune the car otherwise your are messing with a whole lot of unknowns from the open source tune. That could very well be causing the issues your experiencing.
Honest Bob is offline   Reply With Quote
Old 03-18-2013, 02:21 PM   #5
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Yeah it could be. Only reason i haven't tried to check was bc i thought since the utec took control at a certain variable it wouldn't matter except for idle, or am i thinking wrong?
Old 03-18-2013, 02:25 PM   #6
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Oh one other thing, i dont have a tactrix cable yet but i do have another ecu from my 03 wrx. Would it hurt to try the 03 computer on the 02 car until i got a cable to flash?
Old 03-19-2013, 10:14 AM   #7
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
The Utec uses what's on the ecu as its base point, an 03 ecu will work fine on an 02.
