Old 09-21-2002, 07:12 PM   #1
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Default Rear o2 readings.
Havent had a chance to swap my front and rear sensors yet. Does the rear, read rich/lean or just slower than the front sensor?
Additionally, Ive heard you need a special socket for o2 sensors. Is this true, and where can I find one? Sears didnt seem to have it.
Thanks
B
Midwayman is offline   Reply With Quote
Old 09-21-2002, 08:10 PM   #2
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
I used a 7/8" wrench for mine. The readings might be off a little, since there's a cat in the way, but I'm not sure if it'll read rich or lean
Impreza Rider is offline   Reply With Quote
Old 09-22-2002, 03:41 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You can get the socket at pretty much any decent parts store that is worth their square footage of stock. I got mine at NAPA.
Be careful with them... my rear O2 is permanently stripped, even after being rethreaded and fitted with a new O2 sensor. I decided to leave mine in there and run a spare one in the front for the Haltech.
Old 09-22-2002, 05:22 AM   #4
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I think you mean you want to swap the rear to the front and the front to the rear. I don't think it would be a good idea to swap these sensors. They are different and take different readings. I think the ECU would get very confused if you swapped them. The second o2 sensor is basically only there to see if the cat is working correctly. Also, subaru has a bad habit of not using anti-seize compund when they install these at the factory. Hence, stripped threads. I stripped mine when I removed the O2 sensors to install them in the uppipe and downpipe. JUst go buy a $25 GM o2 sensor and have an extra hole drilled and bung welded on. Make sure to do it before the cats so you get an accurat reading from the gauge.
Drac9 is offline   Reply With Quote
Old 09-22-2002, 10:51 AM   #5
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Drac, he's running a Link, so it won't really matter which one is where.
Old 09-22-2002, 02:26 PM   #6
Drac9
Member#: 9861
Oh, my bad Swap away then. Just don't be surprised if you have to buy new O2 sensors after stripping the old ones. Subaru needs to start putting some anti-seize on these things. Oh, and not cross-threading them would help a lot too.
Which the ECU read rear O2 sensor values on '07 STi? hotspoons Engine Management & Tuning 2 07-16-2007 02:47 PM
No reading from Rear O2 sensor cyberwilly Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-08-2007 09:41 AM
rear o2 sensor reading droopy172 Electrical & Lighting 0 07-06-2005 06:02 AM
Votage readings at rear O2 sensor EMS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-16-2002 11:42 AM
Front and rear O2 sensor voltages? Anybody get a reading yet? delectron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-12-2001 04:09 AM
