Old 09-21-2002, 07:23 PM   #1
#522
Member#: 2185
Default Coil Questions for 2.5RS
Quick question:
Does this car have a single or multiple ignition coil?
If single, where do I find the Negative terminal?
If multiple, does anyone know where the tach signal wire is?
Thanks
#522 is offline   Reply With Quote
Old 09-21-2002, 08:22 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
What year 2.5? It should have a coil pack type setup. It will have three wires. If memory serves me correct. One lead is the pos. lead or trigger lead, and the other two are negative leads that go to the two coils.
The tach signal.....I'm really not sure.....
Legacy777 is offline   Reply With Quote
Old 09-21-2002, 11:49 PM   #3
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
If you're hooking up a tach you can use the trigger wire...
01RS has two coils in one housing that mounts on top of the intake. Two spark plugs fire at the same time.
What are you doing?
ImprezaRSX is offline   Reply With Quote
Old 09-22-2002, 02:58 AM   #4
#522
Member#: 2185
Thanks for the replies, I do have an 01 RS. I am hooking up a small shift light. It calls for a connection on the neg terminal on the coil or on the tach signal wire. Is it easy to tell the wires apart pnce I get there? Color coded etc?
Old 09-22-2002, 03:30 AM   #5
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
You know..... now that I think about it... I think you have to go to the wire connected to the ecu because of the dual coils....
However, if you do a search, I'm sure somebody has done it!
Old 09-22-2002, 04:06 AM   #6
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
hey man,
try this link
http://www.northursalia.com/m...ingdiagram.pdf
this is the complete wiring diagram in pdf format.
or just check out the site. This guy has other good tech information that could help you out.
http://www.northursalia.com/m...g/2001ecu2.jpg
http://www.northursalia.com/m...g/2001ecu1.jpg
http://www.northursalia.com/m...g/2001ecu3.jpg
these are more targeted towards the ECU wiring.
Old 09-22-2002, 12:49 PM   #7
#522
Member#: 2185
Thanks again, I'll check those links, I've been to his site before.
WTB: coil pack for 2.5rs (99-01) couldnthinkaone TXIC Private Classifieds 0 03-08-2008 01:23 PM
My cgm sti hood for your 2.5rs cgm hood, and my cgm sti wing for 2.5rs wingless NYC Sti_ck_IT Private 'Wanted' Classifieds 15 08-16-2007 10:42 PM
WTB: Ignition coil for 2.5RS GirlySpeed Tri-State Area Private Classifieds 0 05-11-2006 06:11 PM
FS: Coil Pack for 2.5 N/A Rice & Gravy Private 'For Sale' Classifieds 1 05-07-2006 05:02 PM
two imp. questions about 2.5rs tranny... Otaku64 Normally Aspirated Powertrain 3 06-03-2001 10:00 PM
