Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 03-18-2013, 03:24 PM   #1
Goober
Member#: 243164
07 WRX
Default Greddy Type S Bov Bolt Replacement?
Hi guys, I have a Greddy Type S Bov, but I am missing the top bolt piece for it. Would anyone happen to know what kind of bolt it uses? I was thinking it could use any bolt that it could fit. When we installed it with a bolt on it, my car would idle really funny, like it was leaking air or something. Any clue?
Goober is offline   Reply With Quote
Old 03-18-2013, 07:15 PM   #2
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
To be honest you should just use the stock recirc BPV. Most of those type of after market BOV leak. When you VTA you are letting out metered air and cause your car to run rich. Does your car currently backfire? that B why.
But if this is all info you knew I will let that go and say take it to lowes and find a bolt that fits can you take the whole thing apart? What does that bolt connect to inside?
medamullet is offline   Reply With Quote
Old 03-18-2013, 09:09 PM   #3
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Stock BPV is good to 22.5-23psi of MRP at our altitude. Go back to stock and or make sure it doesn't leak!
907Bum is offline   Reply With Quote
Old 03-18-2013, 10:14 PM   #4
fl4tout
Member#: 342603
2002 wrx
riot red
If your gonna vta what bov would you recommend?
fl4tout is offline   Reply With Quote
Old 03-19-2013, 01:15 AM   #5
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Get a speed density tune and run a tial. Perrin, tial, aps are about the only brands I recomend. Both perrin and aps you can run either vta or recirc.
Old 03-19-2013, 01:19 AM   #6
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Take your tmic off and build a pressure tester to put on the 90* coupler. You will need to block off the throttle body with a cap from home depot. Drill and tap a fitting for the bov hose in that cap so the when you start pumping it up it will have pressure against the diaphram. Now watch and see where it starts to open up or leak
Old 03-19-2013, 02:03 AM   #7
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Tial . If your staying stock tmic location perrin is a good way to go.
