Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 03-18-2013, 09:32 PM   #1
scoobytreats
Member#: 267960
2004 WRX
Default 04 wrx retro fit
what do you guys think?
scoobytreats is offline   Reply With Quote
Old 03-18-2013, 09:34 PM   #2
scoobytreats
Member#: 267960
2004 WRX
Old 03-18-2013, 09:37 PM   #3
vf22Bugeye11
Member#: 272096
2002 6Speed swap wrx
Function Warrior!!
great job man!! Thanks for doing it the right way
vf22Bugeye11 is offline   Reply With Quote
Old 03-18-2013, 09:39 PM   #4
scoobytreats
Member#: 267960
2004 WRX
it was a pain but soooo worth it. thanks man
Old 03-18-2013, 10:02 PM   #5
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
what do I think?
It's kickass!
aerosaaber is offline   Reply With Quote
Old 03-18-2013, 10:20 PM   #6
scoobytreats
Member#: 267960
2004 WRX
thanks!
Old 03-18-2013, 10:22 PM   #7
CobbWRX
Member#: 310040
2004 WRX and 15 sti
what kit did you end up going with? I really want to do this
It looks amazing btw
CobbWRX is offline   Reply With Quote
Old 03-18-2013, 10:35 PM   #8
scoobytreats
Member#: 267960
2004 WRX
i did cheap hid ballasts from xenonsupply.com
Old 03-18-2013, 10:35 PM   #9
scoobytreats
Member#: 267960
2004 WRX
and morimoto bi-xenon mini projectors with shrouds
Old 03-18-2013, 10:38 PM   #10
scoobytreats
Member#: 267960
2004 WRX
the retrofitsource.com is a good supplier
Old 03-18-2013, 10:57 PM   #11
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Old 03-18-2013, 11:01 PM   #12
silvercookie
Member#: 180033
2005 WRX
Can you post a list of parts used?
Those came out really good.
silvercookie is online now   Reply With Quote
Old 03-18-2013, 11:04 PM   #13
jimbosv650
Member#: 261307
04 wrx wagon
Nice job. It was night and day for me when I did it.
jimbosv650 is offline   Reply With Quote
Old 03-18-2013, 11:28 PM   #14
scoobytreats
Member#: 267960
2004 WRX
http://www.theretrofitsource.com/pro...roducts_id=206
http://www.theretrofitsource.com/pro...oducts_id=3181
and cheap hid kit from xenonsupply.com
some cutting was needed on the shrouds
Old 03-19-2013, 10:47 AM   #15
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Good job.
You know you could also purchase a high beam splitter ( http://www.theretrofitsource.com/pro...oducts_id=9717 ) so you can have the oem halogen high beam and biX solenoids working at the same time. The downside is you need to disable the DRL unless you're not worried about the small current flowing through the high beam circuit all the time the car is running and the low beams are off.
Mini H1 is a good upgrade from the oem low beam reflector. But once you get used to observing the details of a projector HID output, you may want to do another retrofit with something more efficient in one or more aspects.
satrya is offline   Reply With Quote
Old 03-19-2013, 09:58 PM   #16
scoobytreats
Member#: 267960
2004 WRX
yea i plan on getting the spittler soon but they work for now and look good enough for me, who know i may redo them sometime and change it up.
Old 03-19-2013, 10:51 PM   #17
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
wow that came out really nice, good job
Bak3rSkat3r is offline   Reply With Quote
Old 03-24-2013, 11:40 AM   #18
thegrk86
Member#: 350920
looks great. nice job
thegrk86 is offline   Reply With Quote
Old 03-24-2013, 12:21 PM   #19
Andrew025
Member#: 303408
04 STi
Originally Posted by satrya View Post
Good job.
There is no DRL on the USDM 04
Andrew025 is offline   Reply With Quote
Old 03-24-2013, 03:17 PM   #20
jm02466
Member#: 282876
05 LGT Limited
04 WRX Wagon
This is false. There most certainly is DRL on the 04s.
jm02466 is offline   Reply With Quote
Old 03-24-2013, 03:26 PM   #21
jimbosv650
Member#: 261307
04 wrx wagon
Could have fooled me. I distinctly remember disabling mine.
Old 03-24-2013, 03:39 PM   #22
Mr. AWDriver
Member#: 176505
07 SWP STI
Looks great, I did this on my 04 wrx too. Using theretrofitsource. Time consuming but worth it. And yes there were drl's on the 04.
Mr. AWDriver is offline   Reply With Quote
Old 03-24-2013, 06:16 PM   #23
Andrew025
Member#: 303408
04 STi
Well, apparently mine had been disabled then
Old 03-26-2013, 01:43 PM   #24
04nitewrxrider
Member#: 351477
Default 04 wrx wagon
I recently purchased an '04 wrx wagon, and was wondering if an STi front splitter will fit said wagon? I'm all new to the 4 cyl. turbo world guys so go easy on me. I grew up on American muscle, and due to having a child recently had to trade in my '09 Challenger R/T. Any info would be appreciated.
04nitewrxrider is offline   Reply With Quote
Old 03-26-2013, 08:51 PM   #25
jimbosv650
Member#: 261307
04 wrx wagon
Front splitters(bumper caps) will fit with small holes cut into the bumper and adhesive. A front splitter(lip) will fit with either the aforementioned caps in place, or by cutting off the tabs and custom mounting.
