Old 03-20-2013, 03:38 AM   #1
Llama_
Member#: 341041
2013 STi hatch
Default Is short ram scoop needed for cobb sf intake w/ airbox? 2013 sti
Heya, I just installed my intake with airbox but my MAF gets in the way when I try to put my short ram scoop back on (the long flat piece that directs air to intake). Do I even need this or will it impede the flow of air to my intake? Thanks
Llama_ is offline   Reply With Quote
Old 03-20-2013, 03:56 AM   #2
sc00by4life
Member#: 97135
that would be a snorkle.
no you dont need it, especially at this point.
hopefully you got yourself an AP to go with the intake.
Old 03-20-2013, 04:01 AM   #3
Llama_
Member#: 341041
2013 STi hatch
Of course. Got my up to date stage 1+ map. I am not that uninformed about my car. At which point would I need the snorkle? Also, I always thought the snorkle was the intake silencer on the stock piece.....?
Old 03-20-2013, 05:52 AM   #4
GrumpyPitbull
Member#: 313311
You must have installed something wrong. I have that same intake, and my snorkel fits just fine. In fact, the box is designed specifically to make use of the snorkel.
Is it needed? No ... But why would you not want extra outisde air blowing directly into the box?. I would mess around with it some more ... It should fit with no issues.
GrumpyPitbull is offline   Reply With Quote
Old 03-20-2013, 07:06 AM   #5
bunda4th
Member#: 314503
2012 WRX Sedan
Try loosening things up and twisting the filter/maf to clear anything it may be touching.
Make sure that you are putting the snorkel on with the top cover off the airbox, then fitting the top cover in.
bunda4th is offline   Reply With Quote
Old 03-20-2013, 12:14 PM   #6
ALOKIN
Member#: 348177
2013 WRX STI Limited
600whp IAG CD goodness
What he said ^^^^^^ I put mine on a few weeks ago all fit fine.
ALOKIN is offline   Reply With Quote
Old 03-20-2013, 07:14 PM   #7
yes4idol
Member#: 316621
2012 WRX Hatch Stg 1
Cobb SF Intake, SPT CBE
If your Cobb SF Intake came with the box, you should only tighten the bolts after you put the scoop back on.
http://www.youtube.com/watch?feature...&v=ExX1W1t_oaY
yes4idol is offline   Reply With Quote
Old 03-22-2013, 03:23 AM   #8
Llama_
Member#: 341041
2013 STi hatch
Thanks for that vid lol. I actually talk to that guy a lot on instagram.
