Old 03-20-2013, 09:01 PM   #1
turbofreak79
Member#: 277093
2008 Impreza
Default Tuning.
Hey guys i was wonder are there any plug and play tuning software out there for n/a imprezas.
turbofreak79 is offline   Reply With Quote
Old 03-20-2013, 09:10 PM   #2
2.5ReallySexy
Member#: 167943
Unless you have a ton of n/a modifications the money/ time versus power gain would not be worth it
2.5ReallySexy is offline   Reply With Quote
Old 03-20-2013, 09:15 PM   #3
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Tactrix cable open port 2.0
Rom raider
Steve2.5i is offline   Reply With Quote
Old 03-20-2013, 09:17 PM   #4
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
forums.nasioc.com/forums/showthread.php?t=2017329
As the person above me said but if u decide u want to go through with it, I'd call/txt Mikey his contact info is on the last page.
Old 03-20-2013, 09:42 PM   #5
klaus_b2
Member#: 318411
17 WRX
CWP
cobb/rallitek used to make an accessport if you can find one used. ive got one, only payed 200 for it, but i wouldnt pay anymore than that considering theres really no power gains from it.
klaus_b2 is offline   Reply With Quote
Old 03-20-2013, 10:00 PM   #6
Uruchima
Member#: 322246
2013 WRX Sedan
Do what I did, Get yourself a nice Cold Air Intake, a Nice Catback Exhaust, Call STiMikey, using a Tactrix Cable (with ECU FLASH and rom raider software), get the open source tune... it wont give it that many extra ponies, but it will definitely make it feel a little torquier and if you got a decent suspension upgrade list then you can have lots of fun while DD or at AutoX events...
-fellow 2.5i Open Source with:
COSMO CAI
OBX CATBACK
PERRIN Rear Sway Bar
Eibach Springs
Tanabe Front Strut Bar
Hankook V12 Evos
Uruchima is offline   Reply With Quote
Old 03-20-2013, 10:07 PM   #7
turbofreak79
Member#: 277093
2008 Impreza
Well i would like to get a little bit more power but i would like a better throttle response and better fuel economy too
Old 03-21-2013, 05:59 PM   #8
PA-Outback2000
Member#: 161832
2000 Outback Limited
lightweight pulley helps on response. grounding kit helps a bit on mpgs. i wouldalso get a track pipe or high-flow cat.
with an intake, pulley, grounding kit, header, cat, and catback i got around 30mpg on a trip to long island one summer.
PA-Outback2000 is offline   Reply With Quote
Old 03-25-2013, 08:32 PM   #9
turbofreak79
Member#: 277093
2008 Impreza
Where do it get the pulley kit. I saw perrin and cobb has on but that only for crank. I saw one for alternator and power steering
Old 03-26-2013, 09:51 AM   #10
SkeetZ18
Member#: 338831
08 Legacy GT LTD
QSM
SkeetZ18 is offline   Reply With Quote
Old 03-27-2013, 12:19 PM   #11
PA-Outback2000
Member#: 161832
crank from perrin, alternator from beatrush in japan. search laile.jp and see if you get to the site.
Old 03-29-2013, 02:39 AM   #12
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Grimmspeed for the crank pulley. You have a stretch fit A/C belt and Grimmspeed is the only one set up to work with the gates tools to slip the belt back on. Also the Perrin is a bit lighter but reviews are not as good.
Bababou is offline   Reply With Quote
Old 04-02-2013, 02:33 AM   #13
turbofreak79
Member#: 277093
2008 Impreza
I dont know man that turbo kit for 3400 looks really tempting haha just kidding.
Old 04-02-2013, 12:19 PM   #14
08 OutbackSport
Member#: 321935
2008 Outback Sport
Black Obsidian Pearl
If you want better throttle response try the avo dbw throttle controller. I've heard good reviews. It's a little on the pricey side though.
http://www.avoturboworld.com/avoshop...2007-p-58.html
08 OutbackSport is offline   Reply With Quote
Old 04-16-2013, 10:02 PM   #15
end_of_silence
Member#: 85565
2005 Saab 92x Aero
DSM
You can do the same thing with a Tactrix. Besides being cheaper, you can do soo much more.
end_of_silence is offline   Reply With Quote
Old 04-16-2013, 11:05 PM   #16
Theglovebox
Member#: 353701
Default Need help sluggish impreza
I have a 96 Brighton with an ej22 swap. The car runs really sluggish under load. Im pretty sure it is the knock sensor. There is one the motor but not plugged in, there is also no harness or clip to plug it into. I need a how to to wire it directly to the ecu.
Theglovebox is offline   Reply With Quote
Old 04-16-2013, 11:05 PM   #17
Theglovebox
Member#: 353701
Default Bump
Bump................................
