Old 03-21-2013, 12:22 PM   #1
BBY_Hero
Member#: 234236
06 STI
AW
Default 2002 WRX Clutch Squeak?
Sooo I have a 2002 WRX and the clutch is fairly new yet in first and second gear you can kind of hear a squeak when engaging the clutch i did some research and people have said it's probably the throw out bearing and it doesn't really effect anything the cars are just known to do this.
Help... please haha
Thanks,
Ben
BBY_Hero is offline   Reply With Quote
Old 03-21-2013, 12:27 PM   #2
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I think it might just be where the slave cylinder piston meets the clutch fork. On older cars the grease in the slot dries up and squeaks when you depress the clutch. Either spray it with lube, or pull the slave off and put a dab of grease on it to see if the noise goes away.
2gnt2wrx is offline   Reply With Quote
Old 03-21-2013, 12:41 PM   #3
BBY_Hero
Member#: 234236
06 STI
AW
Oh okay i will try that can you send a pic of the slave cylinder? I'm not exactly sure where it is on these cars. I've only had it for 2 weeks
Old 03-21-2013, 03:02 PM   #4
Member#: 301037
2004 Forester XT
If it is the throw out bearing it should happen every time. Does it make any noise while the clutch is in and held there?
art@grimmspeed is offline   Reply With Quote
Old 03-21-2013, 03:55 PM   #5
BBY_Hero
Member#: 234236
06 STI
AW
No only when engaging the clutch in first and in second gear. It has occasionally in third as well but maybe i just cant hear it and it always does?
Old 03-21-2013, 04:06 PM   #6
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
http://www.toronto-subaru-club.com/f...rk-rattle.html
There is a pic of what I'm talking about.
Old 03-21-2013, 05:40 PM   #7
Turd Nugget
Member#: 346017
2013 STi Wagon
Satin White Pearl
There is a difference between a squeak and a squeal, if its squeaking, its probably the PP fingers or clutch fork as someone said where there is metal on metal with no lube. What I am understanding is you are hearing a squeal while letting the clutch out? If that is the case yes its most likely the TOB, the good news is the TOB is cheap, the bad news is its labor intensive seeing is you have to pull the trans.
Turd Nugget is offline   Reply With Quote
Old 03-21-2013, 05:49 PM   #8
BBY_Hero
Member#: 234236
06 STI
AW
Oh okay great thanks i'll try that I suppose I Is it accessible on a lift? that you know of like would i be able to see it and spray something on there?
I think it's more of a squeak but I'm not quite sure are either damaging to the car?
Old 03-21-2013, 08:37 PM   #9
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Its not easily accessible without removing the intercooler. Have you tried getting it to squeak with the engine off?
Old 03-22-2013, 07:35 PM   #10
BBY_Hero
Member#: 234236
06 STI
AW
Yes it doesn't I'm now actually wondering if it has something to do with the gas pedal because at low rpm in 2nd and 3rd it'll squeak without the clutch I'll pull the intercooler tonight and put some lube on the piece you mentioned earlier. Its really odd because everything seems to be OK.
Thanks for all the help
Old 03-22-2013, 08:49 PM   #11
Turd Nugget
Member#: 346017
2013 STi Wagon
Satin White Pearl
Neither will dammage the car, but if its a TOB eventually it will probably fail.
Old 03-24-2013, 07:16 AM   #12
bluerx07
Member#: 166176
2007 WRX TR
Whats a TOB and PP fingers, because I have that same problem. Im having my tranny being rebuilt now (for the second time) and want to tell my mechanic to check the TOB and PP fingers.
bluerx07 is offline   Reply With Quote
Old 03-27-2013, 11:57 PM   #13
BBY_Hero
Member#: 234236
06 STI
AW
So I have lubed things and still have a squeak and it's odd because at low RPM while driving and I don't ease on the pedal it'll squeak then too. Any more ideas?
Thanks
Ben
Old 03-31-2013, 12:39 AM   #14
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Have you checked the pivot points in the car? Back when I was a tech, we had some complaints of a similar "squeak." Turns out the noise was coming from the rod that is attached at the top of the clutch pedal and at the point it meets the slave cylinder above the gas pedal.
Mine started to do that and I crawled up under there and used some grease on a brush and lubed her up.
No mo "squeak."
recce02 is offline   Reply With Quote
Old 04-01-2013, 12:24 AM   #15
dictoresno
Member#: 139816
2002 WRX, VF34 swap
i have a small squeak sometimes when releasing the clutch pedal which comes from under the hood. gotta get in there and grease the linkages one of these days.
dictoresno is offline   Reply With Quote
