Old 03-21-2013, 02:18 PM   #1
2004Roo
Member#: 310611
2004 Wrx impeza
World rally blue
Exclamation Loose Gas Cap Check Engine Light/other issues HELP!
Hi everybody. I have a 2004 Stage 2 WRX and have never had any issues with any mods. A few months ago I installed the Perrin Turbo Inlet along with an STI intercooler. Since than my check engine light keeps saying the gas cap is loose. Also, (and this is the real issue) whenever I pump gas It does not start right away. It cranks a few times and usually around the second crank is when it starts. It Idles terribly for about 60 seconds before it goes back to normal. It is REALLY annoying. I've had a few suggestions and have done a few more things to try and fix it. I have installed the following to try and fix it:
Walbro 255 Fuel Pump
Brand new Fuel Filter
Even bought a new Gas Cap from a local Subaru Dealership
I have switched on my AP a few times from stage 1 to stage 2 and no luck.
Any Suggestions?
2004Roo is offline   Reply With Quote
Old 03-21-2013, 02:29 PM   #2
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
Try cleaning you maf sensor. Bad maf sensor will cause hard to start and rough idle or even stall. It can also throw a false code. That would be my guess. I wonder if your local auto part store can diagnose this for free.
SilverBOXER4 is offline   Reply With Quote
Old 03-21-2013, 02:37 PM   #3
2004Roo
Member#: 310611
2004 Wrx impeza
World rally blue
Thats the first time I've heard of that, what the heck it couldn't hurt. I'll be sure to clean off that sensor after work. Was also thinking of going to a tuning shop around here if I have no luck even though I'm sure they'll charge an arm and a leg. Thanks dude!
Old 03-21-2013, 02:41 PM   #4
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
When you said you change out your inlet pipe that's what gave me the idea that you could've tampered with the maf sensor. Good luck
Old 03-21-2013, 02:45 PM   #5
SpamBot
Member#: 287534
Any Suggestions?
Stop throwing parts at something you haven't diagnosed.
Retrace your steps involved in the latest change. Double check everything, including (but not limited to) vacuum lines that may be disconnected (blue vac T behind alternator) or installed in the wrong position (CPC solenoids).
SpamBot is offline   Reply With Quote
Old 03-21-2013, 02:54 PM   #6
2004Roo
Member#: 310611
2004 Wrx impeza
World rally blue
I figured the fuel filter should be replaced anyway and the fuel pump upgrade was in my list of things to do so I just figured/hoped those would resolve it. Good pointers though I'm wondering if I may have rushed the install and left something loose or just unhooked. I'll be sure to retrace my steps and hopefully see what's going on. Turbo Inlet upgrade should not cause these issues so something was altered for sure. Thanks alot!
Old 03-21-2013, 03:02 PM   #7
stop_rallytime
Member#: 225515
Just go to a shop and get raped cause if you never heard of cleaning a maf then you have no clue about your car. Sorry by the way a couple months and you just now you have an issue with it? Turbo = pain in the ball sack
stop_rallytime is online now   Reply With Quote
Old 03-21-2013, 03:48 PM   #8
snobordboi
Member#: 149130
2002 WRB WRX
VF39 Brembos etc
If your gas cap is clicked properly, try checking the wiring to the charcoal canister behind the RR wheel. About 12 inchs back up the wire is a connector that water gets into and corrodes. Solder in some new wire, ecu reset, and you're golden.
snobordboi is offline   Reply With Quote
Old 03-22-2013, 08:44 AM   #9
CrashTestRacer
Member#: 66394
2004 WRX Wagon
You knocked a hose loose to the little blue tee behind the alternator. That will fix the "loose gas cap".
Your idle is another problem.
CrashTestRacer is offline   Reply With Quote
Old 03-22-2013, 10:20 AM   #10
wrxlaunch
Member#: 181298
This or replace the part looks like a diverter valve but ita jus a small plastic piece with vac lines attached
http://i38.tinypic.com/4h7i34.jpg
Part to be replaced has blue T attached.
wrxlaunch is online now   Reply With Quote
Old 03-22-2013, 01:57 PM   #11
Member#: 301037
2004 Forester XT
This is where I would start as it could cause both issues.
art@grimmspeed is offline   Reply With Quote
Old 03-22-2013, 03:03 PM   #12
greenplates
Member#: 239162
Tune up, bro. Read up on here and find a few good things you can clean/maintain.
do this often
greenplates is offline   Reply With Quote
Old 03-24-2013, 06:39 PM   #13
2004Roo
Member#: 310611
2004 Wrx impeza
World rally blue
Think this may causing the issue?? I will check on that and post whether or not that resolves those issues. Thanks!!
