Notices
Old 03-21-2013, 05:49 PM   #1
SCwrx85
Member#: 340328
04 WRX
Default BOV acting funny
So this started as far as i know when i put the BOV (turbo XS type H-RFL) on the car. At light throttle if i shift before 3000rpm its a clear open sound. If i shift at WOT regardless of rpm its fine. Now at light to mid throttle if i shift in between 3000-4000 rpm it doesnt open. The car will rev high during the shift then come back down. I had the BOV on my vr4 last year with no issues. Is this just a subaru thing?
SCwrx85 is offline   Reply With Quote
Old 03-21-2013, 05:54 PM   #2
tec_41
Member#: 346278
04 WRX
Is this bov recirculating or venting to atmosphere?
Unless you're tuned for it just about everyone on here will advise you to swap the stock bypass valve back on. The stock computer assumes you have the bpv recirculating air back into the turbo inlet after the maf sensor. If this air is missing it will mess with your readings and cause some interesting issues.
tec_41 is offline   Reply With Quote
Old 03-21-2013, 07:20 PM   #3
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Even time I see that bov it does the exact same thing. I had mine for about a year and it has always been that way. And the whole bov making the car run rich is hugely exaggerated and misunderstood. It has no negative effect on your car.
People parrot what they read on here constantly so research research research.
boosted25 is offline   Reply With Quote
Old 03-21-2013, 07:21 PM   #4
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Can't "tune" for a bov bud. Sorry.
Old 03-21-2013, 11:40 PM   #5
tec_41
Member#: 346278
04 WRX
Sure you can...speed density, "bud".
Old 03-22-2013, 12:56 AM   #6
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
This is all you need to know.... Aside from tune part..
/thread
GhostSenshi is offline   Reply With Quote
Old 03-22-2013, 01:21 AM   #7
J-mez
Member#: 292727
J-mez is offline   Reply With Quote
Old 03-22-2013, 02:21 AM   #8
CanadianImprezaSTi
Member#: 312159
2004 WRX
I'd hardly call switching to speed density "getting a tune".
On another note, on DSMLink v3 you could actually "tune" for the BOV. There was a script you could activate to stop delivering fuel for a split second after the throttle was released to stop the rich condition right after venting. So it is possible to tune for it but I've never seen anything like that done for Subaru's.
Joel
CanadianImprezaSTi is offline   Reply With Quote
Old 03-22-2013, 09:10 AM   #9
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
I found your problem
jayman4312 is offline   Reply With Quote
Old 03-22-2013, 09:43 AM   #10
tec_41
Member#: 346278
04 WRX
You can tune for a BOV using speed density...But that's kind of the point. Ditch the BOV and use the stock, proven, and reliable BPV.
Old 03-22-2013, 11:17 AM   #11
PSBeachBum
Member#: 279870
2005 WRX Wagon
The BOV is prolly rusty. Oil it up.
PSBeachBum is offline   Reply With Quote
Old 03-22-2013, 12:32 PM   #12
3dbello
Member#: 318602
2003 WRX Wagon
I'm pretty new to my Subaru WRX myself, but when I had a BOV on my Nissan 240SX with an SR20DET my HKS didn't produce any sound at the midrange RPM that you speak of. It only made a "woosh" sound when it was lower and high RPM. As long as the turbo doesn't flutter I think you're safe. Once the turbo starts fluttering that's when I'd worry.
3dbello is offline   Reply With Quote
Old 03-22-2013, 02:12 PM   #13
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
So much of this is bad and/or wrong.
When you hear you're turbo flutter, that's compressor surge. Which contrary to popular believe is not bad for a trubo. Even Corky Bell says it is not bad.
HKS is garbage
Your 240 was using technology thats how many years older than when the wrx was built? My buddies SR20 240 ran fine for a year without the 02 sensor. Those have a lot more room for error, such as using a bad bov.
Old 03-22-2013, 02:22 PM   #14
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Joel
Good info. I tuned my own dsm and never actually knew that lol
Old 03-22-2013, 03:08 PM   #15
greenplates
Member#: 239162
Turbo's sound cool, BOV'S sound even cooler.
You own a Subaru. buy a honda if you want to hear whistling and shooshing
greenplates is offline   Reply With Quote
