Old 03-22-2013, 03:19 PM   #1
duetomorrow
Member#: 332227
2013 Impreza WRX
Default n00b help. '13 WRX burning smell/worse?
So stupidly, I got a car wash before I left on vacation. Bad news was, it dropped to 12 degrees f that night and I left the parking brake on. The next morning, I couldn't move the car, forward or back, it was stuck in my driveway. After a lot of revving and gassing, it jolted and started moving, not without making what my brother described as a loud sickening crack sound and a lot of burning smell. Is this something I need to worry about when I return from vacation?
duetomorrow is offline   Reply With Quote
Old 03-22-2013, 03:39 PM   #2
brapple
Member#: 327032
2012 2.0i Premium
The cracking sounds was most likely the pads becoming unstuck from the rotor.
The smell .... how much and how long did you slip the clutch?
brapple is offline   Reply With Quote
Old 03-22-2013, 04:06 PM   #3
duetomorrow
Member#: 332227
2013 Impreza WRX
Maybe a good 30 seconds, a minute at most. I mean since I'm under warranty still, is it something I should bring to the dealership?
Old 03-22-2013, 06:05 PM   #4
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
They dont warranty against abuse.
im sure you could have yanked up on the parking brake back and forth and that would have broken the bond. Its Ice not cement
auskip07 is offline   Reply With Quote
Old 03-22-2013, 07:37 PM   #5
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
aeoporta is offline   Reply With Quote
Old 03-22-2013, 08:31 PM   #6
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I wouldn't worry about it. My Impreza makes a melting-vacuum-cleaner-belt smell when I need to slip the clutch, so I'd say it's normal.
sgoldste01 is offline   Reply With Quote
Old 03-22-2013, 09:54 PM   #7
duetomorrow
Member#: 332227
2013 Impreza WRX
Originally Posted by aeoporta View Post
Thank you for valuable input.
Everyone else, I really appreciate it. I've never experienced that on of my previous cars so that was kind of new and I tend to worry more than I probably should.
Old 03-23-2013, 11:29 AM   #8
aeoporta
Member#: 334126
Dark Gray Mettallic
so your angry at me because
1 you washed your car in winter
2 you didn't check the weather forecast
3 you probably pulled that ebrake up by ALOT so pads got stuck to rotors,
very securely
4 you don't know how to disengage it without revving the crap out of a cold engine
5 you didn't read the section of the manual about parking in cold temperatures
2 options pour hot water on them or heat them up with something
I would only use the tourch and hammer method if I drove a semi truck so
hot water method for your car. You could also have tried one of those portable
heat lamps, hair dryer, etc.
Old 03-24-2013, 07:58 AM   #9
duetomorrow
Member#: 332227
2013 Impreza WRX
No, I'm pointing out that your trolling a person that is a self proclaimed newbie that made a silly mistake, thus your post only unnecessarily points out what I've already admitted. Furthermore, I really had to move my car and I really had no options in terms of the car wash nor had a place to store my car because of circumstances beyond my control (for starters, I'm currently in Japan for the next few weeks with no one to care for my car while I'm gone and I'm not leaving it a mess while I'm gone).
Tl;dr: why are you posting just to embellish on what I made obvious about my idiocy? Or does it make you feel better to troll new owners?
Old 03-24-2013, 11:30 AM   #10
aeoporta
Member#: 334126
Dark Gray Mettallic
So trolling is equated to pointing out that you should read the manual and use common sense instead of beating on your new car. Hmm you could have even googled for the answer. Yep unamused
Old 03-31-2013, 10:21 PM   #11
duetomorrow
Member#: 332227
2013 Impreza WRX
So as you keep jumping to conclusions, let me also explain a situation to it's fullest because you keep posting implying that I didn't read the manual. For the record, I did, like that part where you're supposed to leave the car in gear to prevent the E brake from freezing. Then that part where I mentioned it was a n00b (see: novice, newbie, inexperienced) mistake (as in, I'm aware that I shouldn't have done it but did it anyway)?
Here's some more unnecessary context of the situation.
-I had about a minute to move my car as it was blocking a family member who had to leave on emergency, so I really didn't have the option to go inside my complex and Google the answer. That also leaves waiting several minutes for my car to warm out of the question.
-I don't have a hair dryer or heaters. I don't live in convenience where we generally need things we rarely use.
-My falling asleep pre-maturely on the couch after work (before I can suggest switching cars with my family member before I fell asleep to the car freezing overnight) didn't help.
-I admittedly never thought about hot water but since this is the first time (again, see beginner) this has happened and I really had to move my car, I was in quite a bit of a panic.
-I washed the car because I didn't want to leave the caked in salt while I left the country for several weeks, but didn't have the time to get it washed otherwise (heavy work schedule).
That's just the tip of the iceberg but I figured rather than tell a boring background and possibly what some may interpret as a sob story, I'd just come forward, admit it was an idiotic newbie mistake, and ask if there was anything I needed to worry about so I don't stress out several thousand miles away for a few weeks.
So despite that, you continue to basically are implying how idiotic I was? So I don't have the right to call trolling?
Good to know that there really is no place on the internet for good ol' fashioned help (because even Google yields Yahoo! Answers which is always 100% reliable!)
