Old 03-22-2013, 07:59 PM   #1
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Default 95 WRX cluster pinout? Inop ALT and temp gauge
I have been trying to figure out why my coolant temperature gauge has not been working in my 95 WRX since swapping motor and harness. I seem to have ohm fluctuation at the ECU if that is what the ECU is supposed to be reading from the temp sensor, but the coolant gauge does not move from dead bottom. Coolant seems to be flowing fine.
The alternator also seems to not be charging properly, there's 9v at the hot wire on the alternator, and in the time it took to burp my cooling system and sit for a bit, the battery dropped from 12.1v to 5v.
Does anyone have access to a cluster pinout, or know what the coolant temp sensor wire should be reading at the ECU?
tenchu is offline   Reply With Quote
Old 03-22-2013, 08:55 PM   #2
seangfy
Member#: 242150
1993 impreza L ej20g
aquafrost blue
There is a good pinout on northursillia site if I remember correctly the temp gauge uses its own sensor unrelated to the ecu on the cross over pipe
seangfy is offline   Reply With Quote
Old 03-23-2013, 12:25 AM   #3
pmugabi
Member#: 280926
There are two sensors on the crossover pipe. The smaller one with one pin produces the reading for the temp gauge. I have not seen any mention of its resistance vs temperature characteristics in the repair manual.
pmugabi is offline   Reply With Quote
Old 03-23-2013, 08:42 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
The temp gauge you need to run a new wire from the back of the cluster to ground. For whatever reason they never seem to have a good ground on G swaps I've done.
Old 03-23-2013, 09:27 AM   #5
tenchu
Member#: 64147
1993 STi RA V LTD
Green
I knew this too, temp SENSOR and temp SENDER. Brain fart, thanks guys.
Do you happen to know the specific pin that needs an additional ground?
Old 03-23-2013, 09:44 AM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Just follow the printed circuit back from where the gauge bolts in.
