Old 09-22-2002, 01:08 PM   #1
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Question Where to find a TEC II NA map?
I tried searching for a baseline map for a NA 2.5 RS but I came up empty. Does anyone know where to find one? I need one to get an idea of baseline numbers to help me understand this thang. I really don't want to wait untill the turbo is on, because I'd like to get a modest handle on it before I'm RST. I didn't put this in the NA forum, because most don't use TEC II on NA cars. hehe maybe there's a reason for that.
seven881 is offline   Reply With Quote
Old 09-22-2002, 01:22 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
I hear you. Im doing the same thing with my link plus.
Most of the turbo maps should be pretty good for you, after all its still a NA car untill it hits boost, and seeing as its a MAP based system, you'll never get into those zones.
-B
Midwayman is offline   Reply With Quote
Old 09-22-2002, 01:38 PM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
I think I know what your saying. I can use the numbers up untill the car would be in boost after 2500 +/- RPM then adjust the numbers after boost RPM to compensate for less air being there. I must be nutz, because I actually enjoy this.
Old 09-22-2002, 04:23 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Sorta... but boost isnt RPM dependant.
If you look at a map, its pressure vs RPM all the way across
Just when you're NA, you wont get above 110kpa or so. You can use the entire RPM band until that pressure.
Old 09-22-2002, 06:33 PM   #5
Austin
Member#: 7089
2016 STi
seven881 - email me and I'll send you shiv's tec2 baseline 2.5 map. Like Midwayman said, you can use a "turbo" map while you're still N/A, you just won't be hitting any of the >105kpa load points.
If you need WinTEC2 you can download it from electromotive's site.
Austin is offline   Reply With Quote
Old 09-23-2002, 12:21 PM   #6
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Cool
Emailed u Austin.
Old 09-23-2002, 05:47 PM   #7
Austin
Member#: 7089
2016 STi
Back at ya!
'05 STI - Stage 2 Map - Where to find? kgelster Open Source Reflashes 2 06-05-2008 10:33 PM
Where to find a ver. II front lip lobsterhat North West Impreza Club Forum -- NWIC 8 08-07-2007 07:31 PM
Need Tec II Base Map cdigerlando Other Engine Management 0 07-02-2006 09:22 PM
where to find stage4 utec 4.2 maps nuhga Engine Management & Tuning 6 09-21-2005 11:41 AM
where to find online maps Gil Off-Topic 6 08-13-2004 06:12 PM
