Old 03-23-2013, 02:32 PM   #1
irish charm
Member#: 340078
2015 Impreza 2.0I
Default HELP! Impreza Rotor Size
Hey all,
-Posted this on rs25.com too.
-checked out this thread - http://forums.nasioc.com/forums/show....php?t=1265631 - they didn't specify the ABS/non-ABS models which I didn't think mattered for rotors......
I need the correct rotor sizes for a 1995 Impreza L sedan with 2.2L engine and AWD with NON-ABS and has OEM 15" wheels.
Story:
I ordered Wagner Part No. BD125367 from Rock Auto, had them installed by a local shop (since it was cold) and then noticed a few brake smells/heat.
According to Rock Auto the rotors I bought stated they fit 4WD and non-ABS with 5 lug for the 2.2L (1995). According to Advance Auto Parts (Online and In-store) they also confirmed the fitment. Having no idea what the OEM size was, I ordered from Rock Auto. Mechanic installed them and threw away the OEM ones and the Wagner Boxes. So now I cannot return them to Rock Auto.
Pulled the wheel off myself and that rotor is too small as evident by the brand new Wagner Thermoquiet pads I put on. You could see how the pad was not fully contacting the rotor and 3/4 of the pad was wearing correctly (bed in) and the other 1/4 was still brand new. Rock Auto won't take the old ones back despite the incorrect fitment based on their information.
Being said, I need a cheap (<$20 per rotor) set. According to rock auto the only ones that will fit are the reybestos 96061R. Reybestos' site states these rotors fit the 2WD and 4WD with/without ABS.
Looking at the Wagner quality (the rotors are extremely smooth) looking like they are not aggressive enough for the semi-metallic thermoquiets I put on. I am also broke and can't afford much and have no need for anything special.
Ending: Rock Auto still appears to be the cheapest but despite searches, owner's manual, forums... I cannot find the correct size. My best guess based on the mistake is that I require 260mm diameters?
Help.............
irish charm is offline   Reply With Quote
Old 03-23-2013, 03:38 PM   #2
jamal
Member#: 71875
98 2.5GT
my wheels fit
Help.............
Yes. To the best of my knowledge only FWD Imprezas got the really tiny 242mm rotors. I think this explains it:
Centric part is 120.47010.
jamal is offline   Reply With Quote
Old 03-23-2013, 11:18 PM   #3
irish charm
Member#: 340078
2015 Impreza 2.0I
so basically I need a 260mm diameter and 24mm thickness?
Is there anything wrong with the Wagner brand ones that are cheaper? I'm sure that I could scuff them a bit to have a nice finish like those centrics
