Old 03-23-2013, 01:43 PM   #1
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
Default OEM to Tokico D-Spec conversion
i have an 07 WRX sedan and i will be replacing the OEM struts with tokico D-Specs W extenders, Swift Sport Springs, TIC Scooby Spacers, and Group N top hats i need to no exactly what has to be switched over from my OEM struts. i have no problem breaking down my OEM struts i just need to no exactly what i have to switch. other then the dust sleeve and upper perch (i will be replacing the bumpstops) what else will be needed
Quatty-24BS is offline   Reply With Quote
Old 03-23-2013, 03:36 PM   #2
teiva-boy
Member#: 22825
conical washer up front
teiva-boy is offline   Reply With Quote
Old 03-23-2013, 04:20 PM   #3
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
A what
Old 03-23-2013, 06:06 PM   #4
ishmehb3n
Member#: 161866
2004 Subaru WRX
Java Black Pearl
I have swift springs and tokico HP's and they are GREAT. I was going to go with the D-Specs but i cheaped out. Great value for the money, swift springs are perfect. Im assuming they will feel even better on your Tokico D-specs.
ishmehb3n is offline   Reply With Quote
Old 03-23-2013, 06:07 PM   #5
ishmehb3n
Member#: 161866
2004 Subaru WRX
Java Black Pearl
I think he means the scooby spacers. You need those for the tokico HPs and the D-specs.
Old 03-23-2013, 06:13 PM   #6
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
For the fronts also tho Iv been told only the rears
Old 03-23-2013, 06:17 PM   #7
teiva-boy
Member#: 22825
Originally Posted by Quatty-24BS View Post
A what
Oh you n00bs so adorable, i want to choke you out.
There is a washer on the front you transfer over under your front top hat. Its a conical washer.
Old 03-23-2013, 06:25 PM   #8
Dougbugeye
Member#: 169781
2003 Impreza 2.5RS
Midnight black pearl
Dougbugeye is offline   Reply With Quote
Old 03-23-2013, 06:29 PM   #9
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
O hey thanks I can use google to
Old 03-23-2013, 06:39 PM   #10
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
I was gonna just get the swifts but my stocks are at 93k miles almost to the end
My car is just a DD I wish I could do somthing cheaper but I found a 06 with the same set up love the look it has so might as well
Old 03-23-2013, 06:47 PM   #11
Dougbugeye
Member#: 169781
2003 Impreza 2.5RS
http://forums.nasioc.com/forums/show....php?t=1589951
This is from a sticky in this sub-forum. Hope it helps,there's a lot of info in this forum if you look for it.
Old 03-23-2013, 07:15 PM   #12
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
Thank u actually very helpful
Old 03-23-2013, 07:46 PM   #13
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I see you're in Kettering.
We're just down the road in Fairfield. Why don't you just give us a ring, set up an appointment, we'll do the install and align it as well.
Turn in Concepts is online now   Reply With Quote
Old 03-23-2013, 07:59 PM   #14
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
How much for an alignment
but I want to do the install
I'm doing the install with some buddies want to be able to say iv done all my installs ( no offense )
I will be purchasing the d-specs, swift springs, scooby spacers, bumpstops, from u guys tho
Old 03-23-2013, 08:31 PM   #15
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
TIC - I can't find the bumpstops on your website for my car do u have a direct link
