Old 03-23-2013, 03:55 PM   #1
MNBD
Member#: 323432
1998 Legacy GT
Green
Default What to do with TGV wiring EJ22T/25D
Everything involved in my build can be found here.
viewtopic.php?f=6&t=26975
-EJ22T/25D
-25D intake manifold and throttle body
I'm in the middle of merging my harnesses and can't for the life of me find an answer to what I do with my TGV wiring since I am using a 25D throttle body and manifold. Any input is appreciated. Do I need to run a different manifold and TB? Thanks in advance!
-Jason
MNBD is offline   Reply With Quote
Old 03-23-2013, 04:14 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
I think you have bigger problems than that. Are you trying to use a wrx ecu and harness with 25D heads? seems like it if you are asking about the tgv wires. That doesn't work, won't run.
On cars with TGV deletes you can just tuck the plugs somewhere you can't see them or for a cleaner look just snip the plugs off and tape up the wires inside the harness.
Old 03-23-2013, 04:25 PM   #3
MNBD
Member#: 323432
1998 Legacy GT
Green
How would that setup be an issue?
Old 03-23-2013, 04:30 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Hope you didn't put a lot of time or money into it. The EJ25D cam gears don't have the right triggers on the back for the EJ205 and the EJ205 gears will not fit.
Old 03-23-2013, 04:32 PM   #5
MNBD
Member#: 323432
1998 Legacy GT
Green
Is this the instance even with a merged harness?
Old 03-23-2013, 04:46 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
yeah.
Old 03-23-2013, 05:03 PM   #7
MNBD
Member#: 323432
1998 Legacy GT
Green
Hmmm. Okay, thanks for the input.
