Old 03-23-2013, 09:36 PM   #1
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Default RCE T2 camber plate install problem
I'm trying to install my RCE T2's and can't get the shaft to stop spinning. I've tried many strap wrenches (broke them all), I've used vice grips on top of the strap wrench to try and get a even tighter hold, nothing will keep the shaft from spinning. It's driving me nuts. Any suggestions?
LIQUIDSK8S is offline   Reply With Quote
Old 03-23-2013, 11:37 PM   #2
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
Call RCE they are very helpful.
Subydude81 is offline   Reply With Quote
Old 03-23-2013, 11:43 PM   #3
vision.dynamix
Member#: 139955
2015 Subaru STI
2001 Honda S2000
What tool are you using?
I dont recall, but they may have a 5mm hex in the top of the shaft which you can insert an Allen Key into to hold the shaft still. You then tighten the nut with a pass-thru socket (Or a standard socket and vise grips)
Or you can try hitting it with the impact. It should have enough speed to spin the nut without spinning the shaft. (This is my go-to method)
Old 03-24-2013, 12:56 AM   #4
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
No hex spot to lock it in place. I looked at all of RCE's posts on the matter and they say to use the strap wrench method. I finally got it to work but it was a huge PITA. I wrapped the rubber from the strap wrench (broken off) around the shaft and the top washer etc, then used nylon straps to wrap even more. I would get it turning a few times until it would bind up and create Herculean grip on its own at which point it would work. I'll post a pic when I get a chance.
Old 03-24-2013, 02:06 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yeah....that is a real pita
i usually instal them on the car and hit it with my cordless impact and call it good
if ya not gonna use an impact of some sort.....gfl
and ive never broken a strut using the cordless impact yet...and ive done a lot of strut installs
Old 03-25-2013, 03:36 PM   #6
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Here's a pic of my method.
Old 03-25-2013, 04:00 PM   #7
richy_21
Member#: 58670
2005 got muuuuu?
Go to lowes I forget what there called like rubber adjustable tie down wrenches, the name escapes me. Like the photo above. It's a two person job. Worked like a champ. Then I rested the top hot bolt on a piece of wood helps it from spinning
richy_21 is offline   Reply With Quote
