Old 03-25-2013, 07:17 AM   #1
xkadajx
Member#: 347572
2013 WRX Hatch
Default Weird noise after front speakers and dynamat'd
Hello All,
Over the weekend I just changed out my front speakers to components and also dynamat'd the outter and inner skin of the doors. After reinstalling everything, I am noticing a weird noise when opening the front doors. (Rear doors are fine)
I installed Polks db6501, not sure if that matters. But I am unsure where the noise is coming from and what's causing it. It sounds like a popping or clicking noise and only occurs when I close the door enough and open it again. Kinda sounds like the hinge is hitting or pushing up against something.
Has anyone encountered this before? Or have any suggestions what it could be?
Thanks.
xkadajx is offline   Reply With Quote
Old 03-25-2013, 07:56 AM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
There's a sliding door stop lever in the door, is it hitting something?
Ive had that lever hook my speaker wire and pull/cut it.. (different car)
Old 03-25-2013, 08:09 AM   #3
xkadajx
Member#: 347572
2013 WRX Hatch
Do you know where in the door it's located? I can try to take the panels off and check.
