Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 03-25-2013, 10:05 AM   #1
Member#: 351325
Default Engine start issue - 2009 WRX
Hello you guys.
I am quite a new member at NASIOC and here it goes my first thread.
I am a proudly owner of a 2009 Impreza WRX (265hp) in Brazil.
When the car reached 55,000km (about 35,000 miles) I sent it to the garage to have spark plugs changed and fuel injectores cleaned. After I realized these maintenances shouldnīt have been done so early, but thatīs another matter.
The problem is, after this job was done the engine takes very long to start. If I leave the car parked for a while, letīs say half a day, engine takes several seconds to start and it looks like cilinders got full of gasoline while it was stopped. After some time making engine to start up, it finally runs and the car accelerates normally. If I turn engine off and right after turn it on again, it starts pretty quickly.
This scenario made me think fuel injectors were leaking but they were tested and are perfectly sealed. Also, o-rings were replaced by Subaru OEM ones. Spark plugs installed are also Subaru OEM.
Does anyone know what else should I put some attention on? Really donīt know what this matter should be.
thank you all!
mario.fernandes is offline   Reply With Quote
Old 03-25-2013, 02:03 PM   #2
Member#: 333030
'05 WRX
Don't assume that because something is new it was installed properly and didn't have any defects. Sounds like a leaky injector. Check your fuel learn and it should be pretty obvious one way or another
corvallisbattery is offline   Reply With Quote
Old 03-25-2013, 05:00 PM   #3
Member#: 290592
15 Outback,
I would pull one of those plugs and check the gap. There are a lot of "Subaru OEM" spark plugs that have vastly different gaps. It's a very easy mistake to make.
mechatricity is offline   Reply With Quote
Old 03-26-2013, 07:09 AM   #4
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
plugs are 6ok item.
424wrx is offline   Reply With Quote
Old 03-26-2013, 07:34 AM   #5
Member#: 224941
09 Wrx
Rally blue
Try turning the key to run a few times before actually pushing it to start. This will prime the fuel pump and get fuel pressure up. If it then starts normal that means the fuel pump is loosing pressure when it sits. If it still starts bad then most likely a leaky injector.
Also is it cranking fast enough? Battery could be Getting weak and cranking to slowly
Dragonfueled is offline   Reply With Quote
Old 03-26-2013, 09:13 AM   #6
Member#: 151809
2007 WRX
OK my car does the same but I k ow my issue. Maybe same for u too but I doubt.
My car has an after market fuel pump. Most fuel pumps have a one way valve in it to keep the fuel pressure up so it starts normal. Mine don't so the fuel pressure drops if not started let's say over night.
If u turn the key and let it prime And build pressure it should start pretty close to normal. Did they change Ur fuel pump? Or it could be a leaking fuel injector.
bboylocob is offline   Reply With Quote
Old 04-15-2013, 10:36 AM   #7
Member#: 351325
Hello folks.
Here it goes a follow up on this issue: I had the fuel injectores replaced by new ones and the engine start is now perfect!
Iīm pretty sure the cleaning procedure damaged one or some of them.
Thank you all.
