Old 03-25-2013, 04:33 PM   #51
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by mtbiker278 View Post
I always enjoy reading your build. Excellent photos and highly detailed. If only all cars could be modded with the thought and attention you put into yours.
Thanks! Should have tons of photos to dump into this thread soon.
Originally Posted by subarulz! View Post
You mean when you change your mind? Maybe start a pool to guess how long this set up lasts before that happens.
I'm really not too interested in swapping to twin scroll. I like the v-band.
Originally Posted by jxlee View Post
If this is only "stage 1," does that mean there is a "stage 2" in the works?
Speeding Bullet it Stage 2
http://forums.nasioc.com/forums/show....php?t=2373009
Originally Posted by Layvon View Post
Well hopefully you can save up for a and get some cans in a reflash in the future it will be like a whole new car all over again. Keep checking in on my thread about May or June I should be getting my 6262 tuned on E85. Aiming for 600 on 25-26 psi. My realistic guess is 585 at 25
With cams, I think those numbers make sense. I would think I could hit 600 with cams. Hopefully someday.
xluben is offline   Reply With Quote
Old 03-25-2013, 04:38 PM   #52
vinny.dtw
Member#: 139718
2011 STi, E85 1.5xtr
WRB, Show and a little GO
Ha. New there was something up your sleeve. And here I had some pity points for you going back to stage one... :P Whole new definition of stage 1.
vinny.dtw is offline   Reply With Quote
Old 03-25-2013, 04:50 PM   #53
KingPest
Member#: 194894
2013 BRZ
2005 STi
Originally Posted by xluben View Post
Bore and hone for 99.75mm pistons. Torque plates attached. NF can comment if anything else was done...
Thanks for the info. Very interested to know if anything else was done. Who did the bore and hone?
KingPest is offline   Reply With Quote
Old 03-25-2013, 04:53 PM   #54
TickTack
Member#: 100353
I suspect you'll want to talk directly to NF Performance for details.
TickTack is offline   Reply With Quote
Old 03-25-2013, 05:09 PM   #55
KingPest
Member#: 194894
2013 BRZ
2005 STi
I would like to, but had no idea who 'NF Performance' is. Their user name has not made very many posts on NASIOC. After some noodling around I have found out that it is Nuke & Fuji Performance.
Hopefully FujiK can jump in and provide the answer!
Old 03-25-2013, 05:17 PM   #56
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Stock cams and journal bearing turbo's were both made based on cost considerations. I was also curious what the stock cams could do. Obviously a 272 or similar would increase my top end output considerably. The journal bearing PTE's have made plenty of power. I just hope it lasts a while. The single scroll turbo was because I wanted to use a v-band setup. I had the manifold made so that if I decide I want twin scroll later I can just get a new uppipe made, and not a whole new manifold
I understand the cost considerations! I wanted to rotate a PTE turbo (the same one you have here) on my build but because we had just done the custom up pipe for my Killer B and the custom EWG exhaust not that ling ago, I decided to stay stock location because of the cost!
If you wanted to go TS you could swap the up pipe, add a gate or a divided single gate and swap the HS housing on your 6266. It would be an easy swap from SS to TS!
Fuel pump has been working well. I have it hardwired and it goes on 100% any time the car is on. I don't think there's any way around this with the OEM fuel pump controller. We had some issues with it overrunning the stock FPR, so I bought a Fuelab FPR. It is working better, but it still won't go below 55psi base pressure. Since I have plenty of injector I would rather drop the base pressure and get some more flow out of the pump, but the FPR just won't go any lower.
You've got the fueling to get to 600 no problem. I'm running the same fuel pump re-wired but through the stock FPC. It works well!
Yes, yes. You sound like Fuji!
I'll take that as a compliment for sure! Fuji is pretty darn smart and talented!!
Please don't take my comments wrong. I absolutely love what you guys have done here with your car and it's good to see it evolve to this.
Fuji's heads work is soooo nice that it's almost a shame to not have at least some 264's or 272's either GCS's or Kelfords. You would have 600 WHP without a doubt and without much sweat from that turbo.
I'm making 560 WHP with my Dom 3.5XTR/ 58 lb./ min. turbo and ID1000cc injectors. You've got another 15-16 lb/min!! I'm not sure if you've seen my thread and I'm not trying to jack here but take a look and let me know what you think! http://forums.nasioc.com/forums/showthread.php?t=2480570
Old 03-25-2013, 05:36 PM   #57
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
If you wanted to go TS you could swap the up pipe, add a gate or a divided single gate and swap the HD housing on your 6266. It would be an easy swap for SS to TS!
I'm making 560 WHP with my Dom 3.5XTR/ 58 lb./ min. turbo and ID1000cc injectors. You've got another 15-16 lb/min!! I,m not sure if you've seen my thread and I'm not trying to jack here but take a look and let me know what you think! http://forums.nasioc.com/forums/showthread.php?t=2480570
You guys are running about the same boost but what about the timing ?
Nothing wrong with a journal bearing turbo at least they are no as expensive to fix as a non rebuildable garrett CHRA
Old 03-25-2013, 05:46 PM   #58
Nuke209
Member#: 108089
2003 WRX
NF Performance
What would you like to know?
NFperformance at gmail dot com
Nuke209 is offline   Reply With Quote
Old 03-25-2013, 05:48 PM   #59
Nuke209
Member#: 108089
2003 WRX
NF Performance
Can easily hit 600 with cams. That's the only thing Ben doesn't have on his setup. After that, sleeves
Everytime Juan
what's it to you anyways
Old 03-25-2013, 05:56 PM   #60
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No....
NOS
Old 03-25-2013, 06:15 PM   #61
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Very nice, i bought the same turbo but non v band. Congrats on making the switch to rotated setup. I like how NF advertises the stage 1 as not much just a 6266.
Dr. octagon is offline   Reply With Quote
Old 03-25-2013, 06:25 PM   #62
manitou
Member#: 193757
2006 XTI Limited
Always fishing Juan!.....hahaha
My boost is at 27 psi, it could be more easily but I'm out of injector. Maybe when ID starts shipping the 1300's, then we could turn it up some more!
Jr would rather I not discuss the specifics of his tuning but I'm really not running much timing. We could have made more torque and easily over 500 but Junior likes to build a very smooth rounded power curve! Sometimes they don't feel as fast because of the way it comes on but they usually prove to be very fast! If Junior wants to comment I'll let him do so!
We'll have to let Nuke comment about his tune here but it looks very good! the torque has a bit more of a peak than mine but that's probably somewhat a reflection of the stock cams.
Both excellent tuners we are making reference to!
Old 03-25-2013, 06:42 PM   #63
juanmedina
Member#: 133146
haha the only way to compared to cars is to know all the parameters
Both cars are amazing machines
track time!
Old 03-25-2013, 06:43 PM   #64
manitou
Member#: 193757
2006 XTI Limited
I missed it first but sorry, sounds like you had to buy a me CHRA
Old 03-25-2013, 06:49 PM   #65
manitou
Member#: 193757
2006 XTI Limited
track time!
Yes both are amazing but this is becoming somewhat the norm here, man there are a lot of nice builds going on right now! Not trying to detract from Ben's car, I love it, it's stealth like mine!!! Most folks have no idea! lol
Agreed track time but I've got a couple upgrades to do before I go to drag radials. I want to run it on my big street tires first!
Old 03-25-2013, 06:54 PM   #66
Layvon
Member#: 195711
STi 04/05/06/07
I think it is funny.. when i first joined in november of 08, 400whp was fast. 500 was crazy and 600+ was wtf are ypu thinking. 600 now doesnt even come.on the radar as off the wall nuts ... when it should. Besides evos id be willing to bet our cars are some of the most fun dollar for dollar.
Kudos to the tuners, shops, engineers and owners who have stuck their neck out!
Layvon is offline   Reply With Quote
Old 03-25-2013, 06:59 PM   #67
manitou
Member#: 193757
2006 XTI Limited
^^^What Levon said! Fantastic job here NF Performance and Ben!! Keep up the great work
Old 03-25-2013, 07:04 PM   #68
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by FuJi K View Post
but these turbos like boost though!
OOhhh Yeaah! It's probably not in it's peak efficiency until 27-28 psi!
Ben, Can I get you to take some photos of my XTI? Your pics are awesome!
Old 03-25-2013, 07:12 PM   #69
Nuke209
Member#: 108089
2003 WRX
NF Performance
15*-21*
Old 03-25-2013, 08:09 PM   #70
SubaL0U
Member#: 322795
Awesome car, guys. 8,100RPM!? What has been done for oiling?
SubaL0U is offline   Reply With Quote
Old 03-25-2013, 08:22 PM   #71
STi MAN86
Member#: 287906
2006 STi
I wonder what this would make on pump gas on say 25psi
Ps. Awsm work
STi MAN86 is offline   Reply With Quote
Old 03-25-2013, 08:26 PM   #72
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I hope you didn't feel too bad for me. Stage 1 may have been a bit misleading...
NF has a shop they use.
Correct. Nuke and Fuji have been posting in this thread.
That was the plan for the SS to TS swap (if I decide to).
Does yours turn on and off? I'm almost positive that's not possible with my car (based on looking at the schematics in the service manual).
I do know that the whole setup would benefit from cams. They're on the list for sure. The turbo has plenty of headroom! And the heads can flow it!
Your build looks great. I have been watching it once in a while.
You guys are running about the same boost but what about the timing?
Always with the timing. Lol.
Yeah, no big deal.
We played with boost in the 27-29psi range and different timing. Nuke decided to go with this for now. I'm sure we'll do some more tweaking here and there.
The long 4th gear in my car seems to make that peak torque really bump up. I'm not sure what gearing your car has, but I know that third gear doesn't peak like that on my car.
track time!
Parameters are all secret
I think I'll try a couple passes on my street tires too. I have RPF1's this year, so they're really nice and light. My car really gets zero attention on the street. Almost too stealthy.
Yeah, a lot has changed in the last 5 years. Even the last 2 years since I joined. People are going a lot faster, and I'm glad to be one of them!
Thanks guys. And thanks to all the guys at NF Performance!
I think that's why NF wanted to turn up the boost a bit. The turbo really likes it!
Sure, I can take photos, just stop on by!
For the 3 photos of my car in this thread I probably spent 3+ hours making them. They're all made of many layers of the same shot with different polarizations. It really makes it look clean and removes reflections.
15*-21*
Well, that's not a good way to keep a secret!
Shimmed the Subaru pump.
Old 03-25-2013, 08:27 PM   #73
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Ps. Awsm work
There was a 2011 STI on here with a rotated 6266 on pump gas and I think it made just over 500WHP.
Old 03-25-2013, 09:10 PM   #74
Nuke209
Member#: 108089
2003 WRX
NF Performance
u know that juan wont know whats really going on
Old 03-25-2013, 09:20 PM   #75
Coldflame6
Member#: 216639
2011 WRX Sedan
OMG...one of my fav cars ever still
Coldflame6 is offline   Reply With Quote
