Old 06-23-2015, 12:51 PM   #1
Tony B
Member#: 327597
Default Front end CLUNK at low speeds
Hey guys and gals, 2005 Subaru STI with stock suspension having some CLUNKing noise coming from the front and rear end while driving at low speeds. The clunk happens after lightly accelerating (0-10mph in a straight line) letting off the gas and then CLUNK! from the front end.
It also sounds like the noise is periodically coming from the rear end as well. I've done enough research to know the rear diff likes to make noise here and there which is normal so I'm not too concerned about it.
Diagnosis done so far
Made sure all bolts in the exhaust, suspension and all mounting brackets underneath are tight and not broken
Grabbed and shook all suspension components with front end in the air to see if the noise could be replicated
No luck so far...I'm going to check the pitch stop tonight after work
Can anyone shed some light on this problem or provide any advice as to where else this noise may be coming from?
Thanks!!
Tony B is offline   Reply With Quote
Old 06-23-2015, 01:14 PM   #2
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
it could be motor/tranny/diff mounts getting sloppy...
isotopesope is offline   Reply With Quote
Old 06-23-2015, 01:32 PM   #3
Tony B
Member#: 327597
That was my first thought, but nothing looks like it's severly aged or rotted out after inspection
Old 06-23-2015, 01:49 PM   #4
mitch808
Member#: 10228
2002 Subaru WRX
Some very common things on an Impreza and your STi.
endlinks either gotten loose or broken
strut clunk (You can regrease them)
as mentioned motor or trans mounts aging
mitch808 is offline   Reply With Quote
Old 06-23-2015, 02:08 PM   #5
MikesSTi
Member#: 412885
2006 Sti
My 06 Sti does the same thing when coming to a stop, I can feel it in the brake pedal. Going to pull the front wheels off today and see what I can find.
MikesSTi is offline   Reply With Quote
Old 06-23-2015, 02:35 PM   #6
Tony B
Member#: 327597
Thanks for info! The endlinks seem to be solid from visual inspection and yanking on them. Is there another way to test their structural strength without popping them off? My guess is if I take them off, they aren't going back on again.
I do plan on getting a set of coilovers in the near future so that'll take care of the random strut clunk I hear in the back end.
Good luck! The clunk I'm feeling is definitely in the suspension/drivetrain. Have you checked the spot welds on your firewall to see if they're damaged or broken? These cars love breaking the welds that hold the pedal assembly to the firewall
Old 06-30-2015, 01:54 AM   #7
jbirish
Member#: 424236
2009 WRX
Pull down or push up on the sway bar and then try to move the end link up/down. That may help to see if there is any play in them.
jbirish is offline   Reply With Quote
Old 06-30-2015, 05:51 AM   #8
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
I HAVE NEVER SEEN ANY REPORTED FIREWALL SPOT WELD ISSUES FOR THE GD CHASSIS.
Old 06-30-2015, 11:46 AM   #9
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
If this is only at slow speeds and you can feel it in the brake pedal, it sounds like brake pad click to me. This is normal on any car with solid mounted calipers (i.e. not sliding pins). To test this, go back and forth between reverse and 1st. If it clicks every time you touch the brake, it's just the pads and isn't an issue.
This doesn't sound like the same noise as the original post.
mrsaturn7085 is offline   Reply With Quote
Old 07-01-2015, 10:59 AM   #10
MikesSTi
Member#: 412885
2006 Sti
Never noticed a clunk in my 300zx with ap 6 piston calipers or my 2011 Mustang with brembos. I ran several kinds of pads with those. But i did what you said and its not uniform, only happens when I come to a stop. I pulled the front wheels off and did not see anything broken or loose. This is my first time using Tein coilover so I might pull those off and go over them for any anything loose or broken.
