Old 03-29-2013, 03:00 AM   #26
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
Default Options
Originally Posted by Imprezaspeed07 View Post
So what does everyone think about the control arms? do the sway bars create that much force? That I should think about replacing these?
The swaybars are attached with high strength bolts, so they generate plenty of force in aggressive driving.
The right side FCA (#75?) looks like it is pretty scraped. I wouldn't be confident in it holding together as it is (from what I can see). Depending on how tight $ is, you could also weld a piece of metal the size of the mount with a hole drilled in the middle to the swaybar mount, or even a high strength washer or four (oversized to match the mount face with a bolt size washer on top).
Replacing the FCA is the safe call, but more expensive. You could always try it with the existing, then find someplace without consequences (WIDE open parking lot) to drive hard, and check for deformation in the mounts afterwards.
dagger108 is offline   Reply With Quote
Old 03-29-2013, 07:37 AM   #27
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Originally Posted by Uncle Scotty View Post
driving a race car on the street is NEVER a good idea
using race car parts on a street car is NEVER a good idea
suspension by swaybar is NEVER a good idea
anybody recommends a 27mm front bar on a gd chassis for the street is an idiot....WAY too much bar
What's your suspension setup? What wld u recommend for a gd.
wrxlaunch is offline   Reply With Quote
Old 03-29-2013, 05:52 PM   #28
vision.dynamix
Member#: 139955
2015 Subaru STI
2001 Honda S2000
I would have no issue using those control arms, street, road race or rally.
Old 03-29-2013, 09:03 PM   #29
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i think that for the street a higher setup with a progressive spring and smaller bars....light wheels/tires---and chassis bracing and bushings is better for most of us
but the fad of slammed/stanced is strong and is really the worst way to go as you end up with no suspension travel and too heavy a wheel/tire combo that the suspension cant control
i have a 21mm front bar and 22-24 rear at 23 and the rest is 'custom' for my needing to be able to go off road for work
but running out of travel and having the strut bottom is inevitable for most who have lowered more than an inch or so
Old 03-30-2013, 01:27 AM   #30
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
i think that for the street a higher setup with a progressive spring and smaller bars....light wheels/tires---and chassis bracing and bushings is better for most of us but the fad of slammed/stanced is strong and is really the worst way to go as you end up with no suspension travel and too heavy a wheel/tire combo that the suspension cant control
i have a 21mm front bar and 22-24 rear at 23 and the rest is 'custom' for my needing to be able to go off road for work but running out of travel and having the strut bottom is inevitable for most who have lowered more than an inch or so
Can you give some more insight?
smaller bars - Check as noted
progressive spring - Swift Wagon? Others? (Is there a sticky that explains progressive springs?)
light wheels/tires - I thought of asking this question - wheel size & weight vs. sidewall roll?
chassis bracing - Strut braces? Fender braces? ? ?
bushings - There's only a hundred or so. Where to start? Point of diminishing return?
Thanks again for all your help.
Old 03-30-2013, 01:46 AM   #31
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
So I guess y'all can't read but this isn't a suspension setup thread. Please don't hijack my thread
Imprezaspeed07 is offline   Reply With Quote
Old 03-30-2013, 01:48 AM   #32
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Run them, they look fine. There's plenty of meat left.
bushflyr is offline   Reply With Quote
Old 03-30-2013, 10:26 AM   #33
Antiharper
Member#: 350489
09 Impreza 2.5i
Reading through this baffles the hell outta me with all these responses. I take links off everyday they pay well but guys being all car savvy I didn't see anyone tell this poor guy, just burn then out with the torch, it takes 2 mins. Unless you've never used a torch then I guess spend hours cutting and prying. For the 50$ a shop would charge, if you don't have the knowledge or the tools just pay it.
Antiharper is offline   Reply With Quote
Old 03-30-2013, 11:05 AM   #34
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
Well I don't have a torch and I would rather do it myself. Everyone has to start somewhere. And it was a good learning experience. I'm probably going to take them to a welder and have them reinforce it.
Old 06-30-2015, 08:40 PM   #35
rad.
Member#: 424705
Already posted this in another thread... I'm just trying to put it in the threads that come up when you search "subaru stripped end link" on google.
Save yourself a hacked up control arm, and pray that you can get the channel locks to grab on the bolt. It's all gravy from there, friends!
Repost:
I came up with a quick and easy solution to this problem today. Check out this picture, and the next 4 after it.
https://www.facebook.com/photo.php?f...7&l=6a69ca8334
Please note, this method relies upon you getting the nut far enough off the threads where you can fit a pair of channel lock pliers, REALLY, REALLY tight. In one of the pictures you can see the pliers I used.... you want something beefy, not dinky. The other thing I didn't mention, is I used a ton of rust penetrant while trying to get the nuts off, before the hex's stripped out about when the nut was about 70% clear of the threads. What I was also doing, to try and avoid strippage, was back out the nut till it starts to get pretty difficult... then spin it righty tighty a little. Then clean the threads of all the rust that will be be splooging out of the threads (if you live in a salty ass region like Ontario, at least).
Even with being THAT careful and slow, I still stripped the hex nut in both rear end links. I replaced my front endlinks with Moog units about a month ago, and one of my OEM end links needed to be cut off due to this BS. Or so I thought Hopefully this will save everyone from busting out the angle grinder / dremmel.
If I just saved you from hacking up your OEM end links (or calling them garbage because the hex has stripped) and having to buy a new set for $150...... I'll accept grateful donations to my rally car build fund
rad. is online now Report Post Edit/Delete Message
rad. is offline   Reply With Quote
