Old 03-25-2013, 06:27 PM   #1
paulowrx
Member#: 280351
Default will v7 engine be a direct replacment on a 04 wrx usdm.
hey i have a 04 usdm 2.0L wrx im thinking of getting a v7 sti engine question what i want to know is that will it be a direct replacemnt simply bolt off and on kinda thing or will their be customizations needed for the swap?
paulowrx is offline   Reply With Quote
Old 03-26-2013, 02:45 PM   #2
paulowrx
Member#: 280351
really.. no one in north america knows?
Old 03-26-2013, 03:54 PM   #3
maxim05
Member#: 97619
04 WRX Wagon
My guess as to why no one has responded is that this question can be answered by reading the sticky at the top of the forum.
If that is not sufficient enough, the search function should be utilized to fill in those gaps. The short answer to your question is that the engine is a direct "bolt on", so no customizations are needed. Wiring is simple as far as motor swaps go, other than wiring in AVCS which can be purchased from IAP as a kit.
maxim05 is offline   Reply With Quote
Old 03-26-2013, 06:58 PM   #4
paulowrx
Member#: 280351
thanks very much for the help maxim05 very much appreciate it.
Old 03-31-2013, 10:44 AM   #5
Scooby2002
Member#: 291441
2004 WRX
I just got a v7 swap into my 04 WRX. I had a shop do it so I didn't actually do the work myself. I did get the JDM ecu and wiring harness so it was pretty straight forward and everything works, including the AVCS.
I would highly recommend the v7 if you're looking for a new motor. It surprised me the first time I pushed it hard and it really is very smooth.
Also make sure to get it tuned before pushing it. I get boost creep and had to upgrade the stock injectors and my fuel pump. Not sure if you will have to or not but getting it tuned will tell and better safe then sorry.
Scooby2002 is offline   Reply With Quote
